1. JustAlfo's Avatar
    ****Found the fix, I just needed to unbrick the phone***
    Alright, so basically I rooted my phone when I got it last year and deleted a bunch of the preinstalled apps that I did not want. (For more space) Well last week I get this update notification for a new OTA update. I try to update, it gets to about 30%, then the android guy falls over with the red sign, and the phone reboots normally and I get the update notification again. I tried multiple ways to get this notification to go away, such as the apps that disable the update service. They aren't permanent and I would have to reapply every reboot, so I got tired of that real quick. Then I noticed that I was not receiving incoming calls all the time, so I figured maybe this OTA update was required and would fix that. I decided to go to backup and restore and restore my phone to factory default. Well after doing this I found out some of the apps I removed... still aren't there.. And I feel like a dumbass. Like for instance I had no keyboard.. I had to download an .apk one just to login to google play again. After messing around fixing my settings back to usual I see the update pop up again. So I try to install it and the same thing happens... It gets to about 30%, then falls over with the red sign and fails. Im basically back to where I was before. Is there anyway I can salvage this? Or should I just buy a new phone? I think I messed it up by removing those unused apps.. I did not know it was permanent =/ Guess I learned the hard way.
    08-17-2014 10:15 AM
  2. srkmagnus's Avatar
    Glad you found the fix. Do you mind sharing the exact details for others to see just in case they run into similar problems?
    08-17-2014 06:58 PM
  3. JustAlfo's Avatar
    I was going to, but I wasn't sure if you guys like links to other forums posted.
    I figured people recover their "bricked" phones... so I wonder if that would work, and it did. This guys guide worked perfectly!
    androidforums.com/virgin-mobile-sprint-optimus-f3-all-things-root/842939-recovery-vm-cwm-6-0-4-8-touch-lg-optimus-f3.html
    The only thing that was off was that to get into download mode you have to take out the battery, plug in the usb cord, put the battery back in, and just hold Volume +.
    It restored my phone to it's out of the box state and everything is working perfectly now. I will never uninstall base apps again haha.
    gherkaul and g3max like this.
    08-18-2014 01:41 AM
  1. OTA Update Process
    By Axellionn in forum Ask a Question
    Last Post: 08-17-2014, 05:04 PM
  2. AT&T LG G3 Wireless Charging
    By matt3166 in forum LG G3
    Last Post: 08-17-2014, 04:42 PM
  3. Replies: 3
    Last Post: 08-17-2014, 11:54 AM
  4. LG G3 video is messed up
    Last Post: 08-17-2014, 11:35 AM
  5. Find My Mobile
    By RobX19 in forum Samsung Galaxy Note 10.1
    Last Post: 08-17-2014, 09:54 AM
