Results 1 to 19 of 19
- 04-20-2011, 06:11 PM
Thread Author #1
- 04-20-2011, 09:16 PM #2
Haha, they go through the trouble of copying the LG logo, but they don't get the size right.
I have my own story of buying Chinese batteries. I needed a high capacity battery for a space balloon I was launching. I ordered a 2200mAh Li-Ion battery off of ebay. It arrived and the packaging said "2000 mAh". Ok, not that big of a difference. I open the packaging and on the battery itself, "1600 mAh". Dang it! Not ideal, but I can still use it. I needed just the bare cell to save on weight. So I dismantled the battery, removed the casing and the protective circuitry. Written on the main cell (probably at the time it was manufactured) was the actual capacity "1200 mAh".... Finally, I tested the cell for it's true capacity: 1000 mAh. Less than half of what I thought I was buying.
Having said that, I'd be interested to know your battery life using this new battery. You'll want to reset the battery stats before testing it, otherwise your battery % will be messed up. - 04-21-2011, 02:36 AM
Thread Author #3
Battery life seems to be about 75-80% what the stock batteries give you. I'm betting these are more like 1200mAh instead of 1500mAh like advertised.
Edit-- I used one of these batteries from noon till 9pm, and still have 71% with very light usage. Seems decent, especially for the price!
Edit2- I used the other battery today, from noon till 10:30, and still have 63% with very light usage. Call me HappyScript!
- 04-26-2011, 05:26 PM #4
I bought this from the same seller and had to sand the edges for it to fit.
I don't understand how the charger works, though. My batteries won't fit in the cradle of the wall charger. The sticker label on the charger says "For M0T MB525/MB520/DEFY" and "This U. Charger Support M0T BF5X". It does look like your wall charger in the picture, though. Could you actually mount your battery onto the wall charger? - 04-26-2011, 05:41 PM #5
- 04-26-2011, 07:11 PM #6
Harmonia Developer for Optimus V, Optimus Elite, One V, Evo V, Evo Shift, Evo V
Donate here if you feel inclined to brighten my day. - 04-27-2011, 03:34 AM
Thread Author #7
- 04-27-2011, 11:30 AM #8
So I just bought some extended batteries for this phone that claim to be 1800mAh. I'll report back on how they perform.
- 04-27-2011, 03:39 PM #9
- 04-30-2011, 05:52 AM #10
I can't get mine to go in easily at all. This might be a case of ignoramus like when I nearly destroyed my Microsoft Office's plastic casing to get to the CD before knowing how to properly open it. But how hard can battery chargers be?!
Here are some pictures:
I know the contacts are on the other side but I can't fit it in any which way. - 04-30-2011, 10:22 PM #11
- 05-01-2011, 12:23 AM
Thread Author #12
- 05-01-2011, 08:04 AM #13
Yeah that is the charger for a motorola battery.
Hence the writing that says for mot mb525/mb520/defy.
Like Jerry said I would contact them and tell them you recieved the wrong charger and see if they will send the proper one with a return label. - 05-01-2011, 08:06 AM #14
- 05-13-2011, 12:22 PM #15
- 07-14-2011, 07:46 PM #16
- 07-14-2011, 08:08 PM #17If You Enjoy My Work, Consider Donating.
Thank You! - 07-15-2011, 01:55 AM #18
- 03-22-2012, 05:24 AM #19
Reply
