Results 1 to 10 of 10
    Default Camera problems?
    Several times when trying to use the camera, it fails to load. I get an error message and then it force shuts the camera. I've tried restarting the phone, removing the battery, etc. Sometimes the camera works fine, other times it doesn't. It just happened again, and I booted the phone in safe mode and the camera worked. So I can't tell if there's an app interfering or not. I also noticed that my SD card wasn't being recognized...said it was unmounted. I pulled it, and stuck the card back in and it seemed to work fine.
    Are these common items, easily foxed or should I return this phone?
  2. #2
    Default Re: Camera problems?
    Sounds like you may have a lemon of a phone. I've not had the issues you are encountering yet. You should take it in to Verizon if you have not rooted yet and see if they have any thoughts on the issue.
  3. #3
    CaptDigB's Avatar
    Posts
    Global Posts
    107 Global Posts
    Sounds like a harware issue. Id call Verizon and get it replaced.
    May be a dumb question, but is it easy to save everything to an SD card so I don't have to waste time setting up a new phone?
  5. #5
    CaptDigB's Avatar
    Posts
    Global Posts
    107 Global Posts
    Quote Originally Posted by TheBigKahuna72 View Post
    Well there is Mybackup pro app to save your apps. Launcher pro will save your launcher settings and icons just not widgets.
    Ended up with a new replacement phone when all was said and done today.
    And also discovered that the phone will stay connected to wifi here at home. The "old" phone that I had to return wouldn't. I just thought that was how it behaved. I had to log in to my router every time I used the browser or an app. Now, it stays connected without asking me to log in....same settings. So I'm guess there was an issue with the other phone as well.
  7. #7
    Default
    Good to hear you got a new, fully-functional phone. Let us know if it makes you feel even better about the Spectrum, now that it works the way it should.
    Sent from my LG Spectrum using Tapatalk
  8. Thread Author  Thread Author    #8
    Yes, there are several issues that having a fully functioning replacement have made me aware of, the wifi being one.
    Another was probably camera or "sensor" issue. But when using an app like Google Sky Maps, moving it around and looking, he image on screen was jerky and hesitant to move at all sometimes. Probably camera related...but new one doesn't have those issues.
  9. #9
    Crap, I just got my kid a vivid, one for myself too. I'm not having any problems but her camera just quit on her. She has restarted vivid and we have dug thru every setting we could find. When we tap camera we just fed a black screen with a simple white camera icon that stays up for a few seconds then just disappears. We can't get the camera or video to come on at all. We were cupping to not have to take it back but it looks like that might be the only option.
  10. Thread Author  Thread Author    #10
    Yeah, on my Spectrum, the camera display would come on, but the screen would be black where there should be image. Then it would crash and give me an error message saying the camera app could not be properly loaded. I even reset the phone and tried again to make sure no app was interfering with the camera. Ended up with a new replacement.
