Results 1 to 5 of 5
    jess701's Avatar
    Posts
    ROM
    SOMETHING BAD AS
    Default Major Problems Help!
    Hello,
    I have a seriousproblem here and I am not sure what to do I tryed everything. I was in the process of a facotry reset on my spectrum and it is rooted I just wanted to delete all my user stuff like contacts and stuff. So anyways I did and now it is stuck at custom recovery I cant do anything tryed factory reset and hard rest still comes back to custom recovery when its done. Does anybody have any clues on this or had this happen please help out if you can. I love my LG Spectrum
  2. #2
    magoxr's Avatar
    Posts
    Global Posts
    62 Global Posts
    Default
    Is there anyway you can take your sd card and place a rom on it and flash that?
    Assuming you can interact in the custom recovery, then the problem should be an easy fix.
    Sent from my VS920 4G using Tapatalk 2
    jess701's Avatar
    Posts
    ROM
    SOMETHING BAD AS
    Default Re: Major Problems Help!
    Well I have no way of downloading anything onto the sd card have no slots on my pc small enough.
  4. #4
    Default
    Do u have any nandroid back ups? Tne problem is you have nothing ro recover to after your factory reset.
    Do u have another device you can put your card into to down load to it at all?
  5. #5
    Go and put that on your SD card and install using CWM. I had the same problem and it fixed it.
B
