Results 1 to 7 of 7
    michaeljares's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default phone won't connect to wifi with excellent strength
    I restarted my phone and cleared all the cache. I am sitting next to my wifi and trying to connect to it with my LG Spectrum which says it has excellent strength, but when I click connect it just stays as 'saved'.....it has never done this before so any help is appreciated.
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Default Re: phone won't connect to wifi with excellent strength
    the first time you tried did you put in the correct password? Are you using the right authentication method?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh, my wifi does not have a WEP password or any password. I live in a very low populated area around very old people who would have no idea how to connect to my wifi. Anyways, I am sure it's the right network...100% positive it is the right authentication.
  4. #4
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    check to see if there is a ip conflict. I would forget the AP then reapply. Also, what type of router (a/b/g/n)?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is a linksys router and it is not a static IP issue.
  6. #6
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    I am not talking about static ips but any ip conflict can cause issues. You also might want to try changing the channel on the router, there might be interference
    Sent from my X-Band Modem... TY Genesis
  7. #7
    hollywoodS14's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try resting the router
    Sent from my VS920 4G using Tapatalk 2
  1. Phone won't connect to PC or MAC
    By bailcam in forum Verizon Droid Incredible
    Last Post: 10-20-2013, 12:30 PM
  2. phones won't connect to wi-fi
    By NicoleW78 in forum General Help and How To
    Last Post: 09-08-2013, 12:34 AM
  3. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum General Help and How To
    Last Post: 11-08-2012, 10:03 AM
  4. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum Samsung Galaxy S3
    Last Post: 11-07-2012, 05:37 PM
  5. Phone won't connect to wifi or 3g network
    By palmer0700 in forum Samsung Replenish
    Last Post: 04-25-2012, 01:39 PM
