A
AC Question
V10 drops wireless constantly and drains the battery fast
I have had problems with wireless with this phone since I got it in November. At first though, it was manageable. If I went somewhere that was an "AT&T hotspot", it would find it and connect to it, but when I was at home or another place with a password protected wifi, it wouldn't connect automatically like it should. This would lead to me sitting in my own house using data without realizing it. I finally just got into the habit of manually connecting to my wireless every time I got home. (it would always connect without a problem and remember the password, once I pulled it up and pressed "connect")
But for the last couple of weeks I guess, it has gotten so much worse. I guess it is since the last update which I didn't even realize happened on the 22nd. I'll be connected to my home wifi and for no reason, it will turn itself off. I'll get a little blue pop up that says internet unavailable with *** So I will connect again which will sometimes take several attempts, just to be knocked out again 2 minutes later.
It is also sucking the battery dry now. I now there have been times that I have forgotten to plug it into the charger at night but it was still close to whatever it was at come morning. Now if it doesn't get plugged in and it is less than 75%, it will be dead in the morning.
