Hi all
I just purchased a high capacity battery 6500mah from Power Max.
The battery life now is amazing but I have a problem that the battery % is not correct.
For example if I used all battery and the phone turned off, I still can unplug the battery and put in again, the battery % is still ~20%
And it's the same for charging, if I charge the phone to 100%, it actually was around 80% after I unplug the battery and put in again.
Does anyone know how to fix this? Thanks a lot.
