After having both of them I say V20, battery life is the same, audio (headphones) way better. V20 is smoother than the edge. It's almost stock Android.
My gripes with the V20 are that the screen on V20 is colder, I prefer warmer screens personally, and the external speaker is pretty weak. Lack of water proofing isn't something I need.
Just did that, thank you.If you go into comfort mode setting and set to low, it takes care of the blue tint. I tested out today at AT&T.
Pixels audio is formidable. I can hear the difference but barely. It comes to the sound stage and more clarity.Having had the V20 for a couple of days I must say, battery life is an issue even when using the battery saver. I can see I will have to have an extra charged battery with me at all times to make it through a day. The S7E lasted Until end of day. The camera is another issue. On V20 it seems to blow out the highlights while the S7E has some definition to them. I prefer the warmer tones of the S7E. Now, as far as feel, the V20 is super light and S7E more solid. The V20 is definitely faster and I like the audio since I use headphones frequently. I'm not sure I would keep it...waiting to test out the Pixel and make a final choice.
Can I ask what car make and model?I'm ditching my s7edge for the v20. While overall I liked the phone, the bluetooth has never worked in my car. My car manufacturer says it's a known issue with newer Sammy phones, my carrier says it's a known issue but after months and months of back-and-forth with Samsung, they never could get it working.
Ironically, the phone before the edge was a G3. I really liked it and would still be using if it weren't for the Sim Card reader no longer functioning.
I had the S7 Edge loaner before getting the V20. Honestly, I prefer the S7 Edge. I'm due a JUMP in November and plan on getting the S7 edge blue coral, hopefully they release it here soon. It comes out in Singapore November 5. If not, I'll just get the black. The V20 is 5.7 inches and the S7 Edge is 5.5 inches, but with the on screen navigation buttons, it's probably like a 5.4 inch phone. The S7 Edge is slimmer and feels better on the hand and I find it faster than the V20, better screen, waterproof, better OS. The only thing I like better on the V20 is the external speaker.
Toyota Prius, though this issue seems to be across a wide range of manufacturers. If you look at the s7 edge forum here or on other sites, you'll see A LOT of people having the same issue.Can I ask what car make and model?
This is driving me nuts trying to decide what to get or if my phone will burn up. Will Samsung brick the phone or will they offer people in the US something similar as in South Korea? I've narrowed my choices to the s7 edge, the LG V20 or buying a cheap note 4. I'll get the s7 if Samsung offers a deal for us to get the note 8 but so far nothing. As far as the V20 goes I want to see one in person first but nowhere has them on display. Best Buy are idiots and say they never heard of the phone and my Verizon corporate stores don't have any in stock or on display. Both the guys at Best Buy and Verizon tell me they wouldn't touch an LG with a ten foot pole. Another interesting thing is my Verizon corporate stores have also pulled all of their s7's off display. The only Samsung they have on display is the note 5, S6, and J3. When I asked why they said it was because of battery issues with the note 7 and S7. I could go back to my s6 but it gets crazy hot from just being on and nothing seems to fix that.
