hi
i just bought lg v20 a couple weeks ago and i have a problem with my battery. i had battery drain so i did factory reset and now it's a little bit better than before but still the battery drain fast. for example it shows me that wifi takes lots of battery but i never use wifi and it's off and it shows that android takes lots of battery and and idle. i dont have many applications and sync is off and i closed eveything that i dont need. i get only 1:40-2 hours SoT. any help? maybe why it shows that wifi takes lots of the battery even that it's closed?
thanks!
thanks!
