1. AC Question's Avatar
    for lg v20
    03-20-2017 10:58 PM
  2. lateck2's Avatar
    As I noted in another thread: Anker is the brand I trust.
    Get a 3.0 or 2.0 version and the size that fits your needs.
    Good to go!
    Lateck,
    03-21-2017 08:57 AM
  3. doug-jensen's Avatar
    for lg v20
    Beware of USB Type C chargers and cables and battery packs. Most violate the specs and there have been lots of cases where a non-compliant Type C charger or cable destroyed a phone or laptop. The experts are Benson and Nathan K who have done extensive tests. You can find them on Google+ or search for their reviews on Amazon. Oddly enough even the charger that comes with your phone may be non-compliant and even dangerous to your phone.
    03-21-2017 11:43 AM
  4. huungryshark's Avatar
    I got a imported v20 from Singapore and with electric adapters and it fits very bad.
    I am scared little bit, I bought RAMPOW USB C with lifetime guarantee (7.99€) but the plug not looks trustable. Shown is original LG cable
    03-21-2017 05:01 PM
  5. jeffhuypham's Avatar
    Just buy the authentic LG battery and external charger, and use your original LG charger. Should be fine.
    https://www.amazon.com/LG-Battery-Ch...cUvbUpU5720419
    03-21-2017 07:47 PM
  6. shawnreum's Avatar
    for lg v20
    Pick up the spare battery with charging cradle. I did, and glad to. Because now I spend 10 seconds popping out the dead battery and putting in a fresh 100% charged battery.
    03-21-2017 07:50 PM
  1. Replies: 25
    Last Post: 03-21-2017, 11:48 PM
  2. A little obsessed about battery life
    By Erm10 in forum Samsung Galaxy S7 edge
    Last Post: 03-21-2017, 05:33 PM
  3. How much battery life are you getting on nougat?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 03-21-2017, 12:17 PM
  4. Replies: 1
    Last Post: 03-20-2017, 07:54 PM
  5. How much battery life are you getting on nougat?
    Last Post: 03-20-2017, 02:51 PM
