1. texaskj07's Avatar
    Wife just got viper on Thursday same time I got my s2 epic 4g touch and her battery life is horrible. I've gone in and tweaked settings and downloaded a battery saver iy helps but still not that great. Anyone else have any ideas that I haven't tried?
    Sent from my SPH-D710 using Android Central Forums
    07-01-2012 04:21 PM
  2. LowRentTechGuy's Avatar
    Is it still required that you run it empty and charge it to full while off to get the battery fully charged. Might help but newer batteries might not require it.
    07-01-2012 10:16 PM
  3. prolongExistence's Avatar
    Not sure what you are considering horrible but my wife gets about 8 hrs of usage out of hers. I think that's pretty bad considering my POS Admiral gets about twice that.
    07-03-2012 12:50 AM
  4. texaskj07's Avatar
    She was getting about 4 hours. I installed 2x battery saver and set her network to cdma only no lte and that seems to be helping to get about 6-7 hours depending on use
    07-03-2012 06:42 PM
  5. gollum18's Avatar
    The same was happening to my stepfather phone it would only last a max of 5 hours before dying, we took it into the sprint store and they said the battery was bad(what I figured) so they ordered him a new one, what I couldn't understand was how his battery WAS bad in the first place he has only had the phone for a month and a half, I honestly think this phone kills battery's cause it gets up past 130 degrees when it is on the charger.
    07-10-2012 12:05 PM
  6. mij9895's Avatar
    My phone lasts about 8 hours and then dies. It has never gone above 118 degrees and only when lightly using the internet. But I think most of my problems are signal related than the battery. How is your step dad's service?
    07-14-2012 10:41 PM
