[CWM][SOURCE] Pure ProjectVenom Recovery
thenameisnigel
1,446
148
63
Project Venom 4.1.2
The official bugtracker is located HERE
Scroll down to post #2 for screenshots, post #3 for changelog, and post #4 for download links.
ProjectVENOM is a free, community built distribution of ClockWorkMod which greatly extends the capabilities of your phone.
#Standard CM Disclaimer;
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up or hard bricking your device, I will laugh at you.
Please post bug reports on The Panda Project issue tracker for these builds. These are UNOFFICIAL Alpha Builds of ProjectPanda for the Sprint Samsung Ga laxy S II Epic 4G Touch (SPH-D710). I repeat this is an unofficial port. If you post issues on the official CyanogenMod bug tracker, they will laugh, and delete it. Post all issues in The Panda Project tracker located HERE.
Credits to Developers:
The entire CyanogenMod team. You guys are awesome!
All my testers (Thanks Everyone)
The people at GitHub (Storing codes, and for verfication of source built rom)
Google (Enough Said)
Private Testers Credits:
No testers yet.
ProjectPanda's Github
All source code is available at https://www.github.com/ProjectPanda . If you'd like to to contribute to CyanogenMod, checkout the device tree at https://www.github.com/ProjectPanda
Device Tree Source code including Ice Cream Sandwich kernel source is now available at http://www.github.com/ProjectPanda for everyone's viewing pleasure.
What Works
Backup & Restore Flashing of zips Wiping of drives
Known Issues
Reboot issue maybe? Untested.
Re: [PORT][CWM]ProjectPanda for Viper LTE
Heh, i can't logcat, I have no computer
Sent from my LG Viper 4g LTE using Tapatalk 2
It should be a option where you can backup your log to your cache partition in the recovery in advanced in think.
Thanks.
EDIT: Okay, from the looks of it, the /emmc and /external_sd isn't being picked up correctly. Some MAJOR revamping has to be done to the recovery but it's safe for flashing.
EDIT 2: Looks as if some mount points aren't correct? Attempting a fix and will re-build.
i tried to get a logcat but it says logcat not found,
edit. tried to get it while in recovery and it said not found. was able to when the phone is booted
Nigel, I assume you are working on the install instructions in the "reserved" space?
Freaking awesome work. You guys are phone ninjas
Sent from my Viper 4G LTE on the "coming soon" network
this a good week on the forum. new unbrick method and now working recovery. great job everyone
When I tried to push it via term emulator it said permission denied... I'm rooted with super user obviously . Am I missing a command? Thanks.
did you type su and hit enter before busybox dd if=/data/local/tmp/recovery.img of=/dev/block/mmcblk0p13?
Put su in the term emulator first and let it grant you the rights. Then continue.
I am. First, I was storing all the storage drivers in the reserved space which woulds be cleared after rebooting but apparently the drivers are not being applied like they're supposed to so the /emmc and /sdcard isn't being correctly loaded.
Do this in terminal, make sure platform-tools is in your $PATH.
adb push recovery.img /data/local/tmp/recovery.img
adb shell
su
Sweet... I wasn't going to root, and just wait for the ota, but not not being able to access my GPS settings via my nfc toggle is starting to piss me off!
Ok sorry last dumb question, how do we enter recovery? Lol
You guys could try to use the flash_image binary to flash it, if someone could confirm it works.
Sent from my SPH-L710 using Tapatalk 2
alan400
