Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By dark_mirage
    Dannyman3819's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Everchanging
    Default Extended battery
    Does anyone have an extended battery if so then:
    How thick is it
    Is it to heavy
    And how well does it affect your usage time
    I was thinking about getting one cause my battery only last 3 hours on mooderate use
  2. #2
    pistos's Avatar
    Posts
    Global Posts
    219 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Extended battery
    3 hrs seems awfully short. Have you implemented some of the common things to extend battery life? For example if you are in a poor signal area, then your battery gets murdered no matter what, so turn wifi on and try to utilize it as much as possible. If you are not in an 4G LTE area, then turn that radio off. Turn off syncing on everything that you don't really need synced under your Google account settings. On things you need synced, turn the sync interval down, making it as long as you can stand, and opt for manual sync only when you can.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Everchanging
    Ya i have ultimate juice defender running. But my cell tower thats like across the street keeps getting worked on so ill set up wifi and see how it is. alright I'll just turned on manual sync and turn the sync interval in juice defender down. Thanks for the tips.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Everchanging
    Also does anyone know any battery saving build.prop tweaks
  5. #5
    dark_mirage's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Let me check xda real quick
    Sent from my LG Viper 4g LTE using Tapatalk 2
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://androidforums.com/elite-all-t...ks-edited.html
    Dannyman3819 likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Everchanging
    Sweet perfect thanks
  1. Droid Extended Battery
    By Jared DiPane in forum Motorola Droid
    Last Post: 05-27-2010, 04:03 PM
  2. Any new News on extended batteries?
    By g.711 in forum Samsung Moment
    Last Post: 01-28-2010, 05:51 PM
  3. Extending Battery Life
    By prchoudh in forum Motorola Droid
    Last Post: 12-17-2009, 09:46 PM
  4. Extended battery for hero
    By Mopar in forum HTC Hero
    Last Post: 12-15-2009, 06:08 PM
  5. Best way to extend Battery Life
    By bigthinker in forum General Help and How To
    Last Post: 12-12-2009, 01:37 AM
