DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By progranade
    Default Slow battery charge
    After updating to ics when plugged into my wall charger and my computer my phone says. Battery is charging slowly due to low electric current of TA/USB connection. Anyone know a remedy
  2. #2
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default Re: Slow battery charge
    Are you using the charger the phone came with?
    Sent from my LG-LS840 using Tapatalk 2
    Yep same factory lg block and cable.
  4. #4
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Not sure why it would do that with the wall charger, mine only does it connected to the pc. Do you have a charger from an older phone to try?
    Tapatalkin it from my Viper running ICS
  5. #5
    Quote Originally Posted by alog122 View Post
    I had that same issue. I don't know for sure if what i did fixed me but i will share what i did. after the I installed the ICS update.zip and seen that. I did a ##786# and enter my msl number and let the phone do it thing and after that I never seen it happen expect when I am plug into my laptop. hope it works for you
    If you like my work or If I helped you. Please show some love and click the thanks button or donate here
  6. #6
    Quote Originally Posted by tommyjoesanders View Post
  7. #7
    Quote Originally Posted by yourunclealbert View Post
    AND when I plug into my computer it will charge the LG Spectrum LG VS920, BUT the computer does not "See it", so I can not even look at the pictures (and stuff) on my smart Phone. I not that smart about the smartphone, but I would think the plug-in on top might be the problem.. HELP--->
  8. #8
    In this upgrade the LG Viper got a change on how it charges when plug into your pc device. It does slow charging when plug into usb port of your PC. and normal charging when plugged into wall or car charger. It's a LG Thing they started doing with phones running ICS and JB.
  9. #9
    I have the same problem..tech support at vrizon thinks its my charger..i say its a processor error..no one seems to know how to fix it..i have the lg intuition. It judt started doing this..please help
  10. #10
    This is the LG Viper forums. Not the LG Spectrum. Go post about it on your own forum. We can't help you.
    Thanked by:
    sandtiger likes this.
  11. #11
    Quote Originally Posted by progranade View Post
    You really should take a look at the way you come off to others....I'm not bashing you, its constructive criticism, you come off rude and obnoxious.
    Thanked by:
  12. #12
    Sorry. I didn't mean to sound like a jerk. Now when I'm looking at it I'm sorry for that. I didn't mean to be a jerk.
  13. #13
    mij9895's Avatar
    Posts
    Global Posts
    142 Global Posts
    This slow charging issue may just be an lg problem, spread across devices here and there. I never had that problem with my Vipers though.
    Current Device: Sprint Samsung Galaxy Nexus Jelly Bean 4.2.1
    Previous Devices: HTC Evo Shift 4G & iPhone 3GS 16GB
  1. Slow battery charging time
    By rtf8vc in forum Verizon Galaxy S3
    Last Post: 04-14-2013, 01:08 PM
  2. Verrrrrry slow battery charge with ICS Kies update
    By sfrrr in forum Samsung Galaxy S II
    Last Post: 05-19-2012, 08:26 PM
  3. Nexus S Slow battery charging?
    By Jalarm in forum T-Mobile Nexus S
    Last Post: 08-04-2011, 10:05 PM
  4. Little Battery Life, Slow To Charge, Self-Corrupting Video
    By Savage1701 in forum T-Mobile HTC Sensation
    Last Post: 06-19-2011, 08:41 PM
  5. Battery charging extremly slow/not charging
    By dmcollins57 in forum HTC EVO 4G
    Last Post: 03-20-2011, 06:18 PM
