Supercharge v6 doesn't work on every phone?
adamsmiley
Active member
Dec 17, 2011
33
What is Supercharge v6? I'm always looking for good battery apps but have not found any good ones this sound like it could be something to do with charging the batter.
hezx
257
14
lol no... its a cpu+gpu script. Either to make it more power efficient or more powerful
dark_mirage
366
It doesn't affect benchmarks, benchmarks mean nothing, but it does make everything much smoother. But for the hell of it, lemme go run a benchmark for you.
Sent from my LG Viper 4g LTE using Tapatalk 2
libertus77
137
Dark_mirage, did you have any su bunary or busybox issues? I'm new to the SuperSU in place of Superuser that came with the rooting method, I used. I'm a big v6 proponent, so wanna get it ran.
Sent from my ICS-Flavored LG Viper using Tapatalk 2
hezx
257
14
SuperSU is personally much better. It has a option to unroot or clean up to use a different superuser app... Superuser has neither of those options. Also SuperSU updates the binary on its own
wolfygang
125
SuperSu has an ption in settings to switch to superuser and you can download a busybox installer in the market
wolfygang
125
hey dark can you link me the init.d support script and also did you get the launcher supercharged on ics? I tried and it said the launcher was patched but it came up as "very weak"
wolfygang
125
I gave up supercharged i kind of think it slows my phone down...
Or I didn't do everything right but I think I did.
It constantly force closes, I'm just going to wait for CM9 to customize stuff
n0ve
252
3
To really get it to work well on ICS since memory mangement is so different than GB, you need to follow all the steps to add maximum multitasking/icscream, personally i deodexed the /system then did the smali edits to get full 100% supercharge +extra options.
kerokekerol
