Results 1 to 11 of 11
- 11-09-2012, 07:39 AM
Thread Author #1
Battery life help
Does anyone have any good ways to save battery? I thought after we went to ICS that it might get better but I can't make it thought the day with out charging my battery and I did not have this issues with my EVO. I already have two apps one to turn off wifi when not needed and one to turn of buletooth when not being used. I think there is any issue with the phone not sleeping right but that is just my thought. I do have it rooted if there is something that only works on a rooted phone I'm open to that too.
- 11-09-2012, 07:49 AM #2
Re: Battery life help
2x battery app will manage your Wi-Fi and data connections well enough to get you through the day.
sent from my LG Viper using my thumb and Swype. - 11-09-2012, 07:50 AM #3
I noticed this too. Once I froze all the stock sprint apps and other apps I dont need it helped the battery life a lot. The sprint apps have a habit of running in the background all the time.
I used Titaniun Backup to freeze my apps. you need the pro verzion to do this but I highly reccommend paying for the pro version. - 11-09-2012, 08:09 AM
Thread Author #4
- 11-09-2012, 08:25 AM #5
Depends what your doing on your phone if your browsing the net 5+ hrs a day this is a battery burner then u will need to charge battery more often
Yes u can use apps to kill apps but I doubt it'll solve your problem
I use my s3 quad to browse net sometimes 5+ hrs a day so i need to recharge again that day sometimes
this is how smartphones are the battery doesn't last forever
I set the screen brightness to about 20% anything more looks too bright for indoor use
I have wifi & gps & bluetooth turned off cos I don't use those functions
I don't use apps to turn apps off
some times if your constantly killing apps through out the day this can be a bigger battery drain than if u didn't kill them
Also ads that are being sent to your phone when u open the app can drain battery more
If u bought a new top of the range car
would u drive it at 50 MPH cos it Burns alot of petrol
I doubt anyone would so why restrict your phone
Maybe get a bigger battery 3000mah or more may be a better solution
Sent from my GT-I9300 quad-core
- 11-09-2012, 09:51 AM #6
- 11-09-2012, 11:17 AM
Thread Author #7
- 11-09-2012, 02:06 PM #8
- 11-10-2012, 06:38 PM #9
In battery usage, screen is always #1 for me, so definitely I would lower brightness...also w/ the option to disable front key lights, id go for that too, ( you know where they are, who cares if its lit right?), nfc off when not needed, auto rotate off, and also I use setcpu w/ profiles...screen off max 810mhz min 384, in call min 384 max 980, and battery < 20% min 384 max 810, seems to help.
- 11-10-2012, 06:43 PM #10
- 11-10-2012, 06:55 PM #11
Samsung Galaxy S Battery Life Help
By Plinkfoyd in forum General Help and How ToReplies: 3Last Post: 05-17-2013, 08:05 PM -
HATE my battery life HELP
By PitbullJunkee in forum Verizon Galaxy NexusReplies: 21Last Post: 01-20-2012, 04:11 PM -
How to save battery life... HELP
By PitbullJunkee in forum Verizon HTC RezoundReplies: 3Last Post: 11-22-2011, 10:15 AM -
New SGS2 user gutted with battery life. HELP!!!
By mpshah in forum Samsung Galaxy S IIReplies: 9Last Post: 10-14-2011, 10:50 AM -
Battery Life Help!!
By KMfiremedic111 in forum Samsung TransformReplies: 12Last Post: 12-08-2010, 03:48 AM
Reply
