Results 1 to 15 of 15
Like Tree5Likes
  • 3 Post By tommyjoesanders
  • 1 Post By tommyjoesanders
    Default Unbrick LG Viper using Android 4.0.4 tot and dll
    Hey Guys,
    Here is the official tot and dll too unbrick your LG Viper with Android 4.0.4 using LG FlashTool.
    Just use this guide http://forums.androidcentral.com/lg-...-firmware.html
    and download the Android 4.0.4 tot and dll. from here
    Second download link -
    Notes-In the zip file I gave you the LGFlashTool and tot and dll.
    Notes- make sure you use the dll in the zip. it is different than before. if you don't use the correct dll the flash will not start and will give you download fail in LG FlashTool.
    Notes- After you get too the homescreen for the first time. Please do a factory reset. Go too System Settings then go too backup and reset and follow the prompts and your phone will be ready.
    If you like my work or If I helped you. Please show some love and click the thanks button or donate here
  2. Thread Author  Thread Author    #2
    Default Re: Unbrick LG Viper using Android 4.0.4 tot and dll
    ICS tot and dll now can be flashed using LG FlashTool
    Thanked by 2:
    wormy987123 likes this.
  3. #3
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    can this be used if already on ics if we have soft-bricked it as well?
    Quote Originally Posted by wormy View Post
    yes you can use it too unbrick regardless. If the phone will go into download mode. It will flash the phone. just like the other firmware versions
    Thanked by:
    Wormy, Do you think I need too write a guide in regards on how too use this. since we have alot of new people that come here now?
    In the zip file. It has the LGFlashTool and tot and dll. Updated the notes as well in OP
  7. #7
    dead link, ill host if u send me ...or reupload elsewher eplease bro?
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by n0ve View Post
    the link not down. I just click on it. I will just too be safe put a mirror link up as well
    OP Is Updated with a second download link
  10. #10
    Quote Originally Posted by tommyjoesanders View Post
    thanks got it going now, cant wait to reformat and then re apply these 4.2 apps, i love the new keyboard, camera, and gallery, camera supports 1080p video as well.
  11. Thread Author  Thread Author    #11
    Sweet. Keep me posted bud
    Thanked by:
  12. #12
    doing a reflash now, fresh sd , and then universal root....if u want to do me a favor in the meantime, download the newest TI back up update, create a recovery update.zip and see how they restore...i believe we'll be able to flash roms via TI backup now 100%.
  13. Thread Author  Thread Author    #13
    do you have the steps too do this. I can't get too backup. trying too fiqure out where I went wrong
  14. #14
    Im gonnna be testing it out in a lil bit, right now im unbricking...went too far porting 4.2 gapps....only stable ones are cam gallery, gmail, gwallet ,keyboard....so far...
  15. #15
    Sorry to revive this thread 6 months later. I am having problems flashing from 4.0.4 ZVK to ZVI so I can gain root.
    NM. Everything worked great. Thanks for the know how and sharing!
  1. Unroot/Unbrick your phone using .sbf
    By ikithme in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 09-17-2012, 05:10 AM
  2. Replies: 15
    Last Post: 08-31-2010, 02:43 PM
  3. using android phone as remote computer
    By CaptainET in forum Android Applications
    Last Post: 08-06-2010, 08:37 PM
  4. LG Finally Doing Android Right?
    By ceriem in forum General News & Discussion
    Last Post: 07-24-2010, 03:29 AM
  5. how to use android market
    By live4spd in forum Verizon Droid Incredible
    Last Post: 05-14-2010, 11:28 AM
