Results 1 to 6 of 6
    Default Problem with battery and scrolling
    Does anyone else have an issue where if your phone is charging and you're playing a game or anything and the battery keeps draining but will sit on 1%?
    Also does anyone have a scrolling issue where if you told your finger on the screen the webpage bounces back on forth?
    I'm kind of thinking my viper is about to die
  2. #2
    mij9895's Avatar
    Posts
    Global Posts
    143 Global Posts
    Default Re: Problem with battery and scrolling
    When i took my phone in last night the tech said my screen was all screwed up. And my phone would continue to drain while plugged in if the battery temp was above 98°.
    Sent from my LG-LS840 Viper 4G LTE using Tapatalk 2
    Current Device: Sprint Samsung Galaxy Nexus Jelly Bean 4.2.1
    Previous Devices: HTC Evo Shift 4G & iPhone 3GS 16GB
  3. #3
    hezx's Avatar
    Posts
    ROM
    Stock
    Battery problem is because your using more power then the charger is out putting. Get a charger rated at 1.2+ amps and you will see faster charging + no more problem... can't help ya on the other sinxe I don't have the problem
    Sent from my LG-LS840 using Tapatalk 2
    Ya i selected the option show touches to see what it is doing and its spazzing the F out constant clicks everywhere
  5. #5
    My phone is normal O.o?
    I found out it is only is doing it while it is charging.
    Sent from my LG-LS840 using Android Central Forums
  1. HELP ME PROBLEM with BAttery and other
    By federodrigo in forum General Help and How To
    Last Post: 07-12-2012, 08:47 AM
  2. Problem with 3G and beautiful widgets
    By chetman7 in forum Verizon Droid Incredible
    Last Post: 09-26-2010, 12:26 PM
  3. Problem with Market and paid apps after 2.2 upgrade
    By MarqBland in forum HTC EVO 4G
    Last Post: 08-10-2010, 08:29 AM
  4. problem with apps and display?...help
    By Kamran1981 in forum Motorola Droid
    Last Post: 01-17-2010, 05:17 PM
  5. problems with camera and battery
    By piper09 in forum HTC Hero
    Last Post: 10-11-2009, 05:45 PM
