Results 1 to 8 of 8
- 11-23-2012, 10:42 AM
Thread Author #1
- 11-23-2012, 12:10 PM #2
- 11-23-2012, 12:16 PM
Thread Author #3
Re: ics battery drain?
No i havent.. How can i back up everything i used ti back up but as for pictures and what not? And ill have to reinstall ti back up once i factory reset?
Edit... I will loss root acces wont i? Or is there a root keeper for that?Last edited by arn1016; 11-23-2012 at 01:08 PM.
- 11-23-2012, 01:07 PM #4
- 11-23-2012, 02:19 PM #5
- 11-23-2012, 02:44 PM
Thread Author #6
- 11-23-2012, 09:57 PM #7
- 11-27-2012, 04:36 PM #8
ICS does allow some battery saving features stock that GB did not..such as homekey lights -> disable...( you know where they are right? ), i never use them...Turn Sync off when you don't care to receive notifications...SetCpu profiles work great for me....lower cpu max to around 800 mhz when screen is off...but to really get the best battery life, go extended ;\...i just ordered a 3600 mah, going to be huge but worth it hopefully.
Post-ICS, Battery Drains While Charging If In Use
By JohnWittle in forum Droid BionicReplies: 14Last Post: 11-06-2012, 08:23 AM -
How To Fix ICS Battery Drain Bug
By JoNex in forum Android 4.0 Ice Cream SandwichReplies: 10Last Post: 11-05-2012, 01:53 PM -
Since ICS upgrade, battery draining 3%/hr while idling
By psufan32 in forum AT&T Galaxy S IIReplies: 67Last Post: 10-01-2012, 08:41 PM -
ICS fixes wifi battery drain?
By whitenack in forum AT&T Galaxy S IIReplies: 9Last Post: 07-09-2012, 08:30 PM -
ICS battery drain
By wvugho in forum Droid RAZRReplies: 1Last Post: 07-08-2012, 01:20 AM
Reply
