Results 1 to 6 of 6
- 12-02-2012, 07:19 AM
Thread Author #1
Ics battery life.
So I went out and bought and actual wall charger, charged my phone to 100% and calibrated then let discharge to 5% then recharged, I just plugged my phone In after 12 hours of normal use it was at 10%. This is a major improvement over the 5-6 hours I was getting for some reason. I honestly believe my battery issues were being caused by the slow charging rate of the factory charger. Has anyone else had similar experiences?
Thanked by: - 12-02-2012, 11:43 AM #2
Re: Ics battery life.
On my Samsung Galaxy S (Fascinate) the charger I had was 0.7 amp output for charging, this charger is 0.85 amp output which besides the charger I have for an HP touchpad (which is 1.0 amp output) this charger is one of the fastest I have ever used for a regular cell phone. Your battery issues were being caused by a not properly calibrated battery which you now did, I would suggest to use the factory charger it was designed for the phone even though you may have a properly working (universal) style charger I have had bad experience with anything other than factory chargers over the lifetime of a phone. And the proper way to calibrate a battery (for anyone that may not know) is to charger to 100%, calibrate it, let drain completely (less than 2%) and then charge to full. Do this for at least 3 full charge cycles and you should see improved battery function. I did notice that when I installed the ICS update it did wipe the battery stats from the phone which is why battery life seems horrid at first. I can say though my experience with ICS on any phone over gingerbread is that you see much improved battery life, if you do not then I would suggest to anyone that may read this to do a battery calibration of your own.
- 12-08-2012, 05:55 PM #3
- 12-08-2012, 07:36 PM #4
- 12-08-2012, 08:25 PM #5
- 12-12-2012, 04:30 PM #6
Sony Tablet S w/ ICS Battery life?
By tamc3 in forum Other TabletsReplies: 15Last Post: 12-27-2012, 10:53 PM -
Motorola RAZR w/ ICS - battery life???
By adamskn in forum IntroductionsReplies: 0Last Post: 07-09-2012, 11:39 AM -
ICS - battery life, browser issue
By x1sspic in forum Droid RAZR MAXXReplies: 2Last Post: 06-27-2012, 10:19 PM -
ICS Battery Life?
By jakedsnk in forum Verizon HTC RezoundReplies: 1Last Post: 05-30-2012, 09:30 AM -
Calkulin's 3.0 (GB) vs AOKP 32 (ICS) -Battery Life?
By deesugar in forum Epic 4G Touch Rooting, ROMs, and HacksReplies: 4Last Post: 04-19-2012, 11:50 AM
Reply
