Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By thenameisnigel
    Josh DeLuca's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Won't boot not into recovery?
    I have an LG Viper obviously, and I sent it into recovery mode from an application with root just to see if it'd work, and now it will only start into recovery and nothing I do will change it, I even did the unbricking method, everything seemed to have worked, then booted up my phone and it went right into recovery.
    Is there anything I can do?
    If you were wondering there are no modifications to my phone other than it is rooted, no CWM recovery, just regular.
  2. #2
    thenameisnigel's Avatar
    Posts
    Global Posts
    1,460 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: Won't boot not into recovery?
    Quote Originally Posted by Josh DeLuca View Post
    One: Did you use ROM manager and flash a different recovery? If so, you're bootlooped.
    Two: You're bootlooped.
    Three: Why did I make a three? O_O
    n0ve likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No I literally just put it in recovery mode and it won't come out now.
    Can I fix it?
  4. #4
    Posts
    Global Posts
    1,460 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Can I fix it?
    Uhh, I dunno. I'm not a Viper user, just a device maintainer.
  5. #5
    tommyjoesanders's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your best bet is too use unbrick method and go back to stock
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tommyjoesanders View Post
    I did and it still boots into recovery.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I fixed it by holding volume down and power and doing a factory data reset, I have no idea why that worked and using the unbrick method didn't.
  8. #8
    n0ve's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Because you must have not been in download mode or changed your port #.
  1. Problems with booting Vortex into recovery
    By oshapley in forum LG Vortex
    Last Post: 12-01-2012, 04:08 PM
  2. Replies: 4
    Last Post: 09-28-2012, 07:06 PM
  3. Booting Straight Into Recovery
    By superbleester in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 06-15-2012, 09:12 PM
  4. Boot Loop - into Recovery only
    By exBlackberry in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 10-12-2011, 10:57 PM
  5. Hero not booting into recovery
    By ebadamageplan in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 12-05-2009, 04:04 PM
