Won't boot not into recovery?
I have an LG Viper obviously, and I sent it into recovery mode from an application with root just to see if it'd work, and now it will only start into recovery and nothing I do will change it, I even did the unbricking method, everything seemed to have worked, then booted up my phone and it went right into recovery.
Is there anything I can do?
If you were wondering there are no modifications to my phone other than it is rooted, no CWM recovery, just regular.
Re: Won't boot not into recovery?
One: Did you use ROM manager and flash a different recovery? If so, you're bootlooped.
Two: You're bootlooped.
Three: Why did I make a three? O_O
No I literally just put it in recovery mode and it won't come out now.
Can I fix it?
Can I fix it?
Uhh, I dunno. I'm not a Viper user, just a device maintainer.
Your best bet is too use unbrick method and go back to stock
I did and it still boots into recovery.
I fixed it by holding volume down and power and doing a factory data reset, I have no idea why that worked and using the unbrick method didn't.
Because you must have not been in download mode or changed your port #.
