Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Like Tree2Likes
    Default Lg viper wifi and 3g problem
    My Viper has been fine for the past couple of months, but recently my wifi and 3g keep going in and out of connection. I have also experienced some issues with my phone getting very hot, but i have not gotten a error message saying it has overheated. I do have a app installed that tells the temperature, It said it was 130 degrees F. The battery says to not expose to temperatures of 103. What do I need to do.
  2. #2
    Default Re: Lg viper wifi and 3g problem
    This happens to me a lot. Just turn the phone off and put the battery in the freezer for an hour or so. If you were charging which I'm pretty sure you were, don't turn the phone on until it finishes charging and then use it off the charger. That usually fixes it for me.
    I am not sure that is safe because your taking it from one extreme to another. This may cause battery performance to go down, for example if someone has frostbite you must slowly heat the affected area up. Should i take the phone in to sprint?
  4. #4
    1) The freezer was a joke.
    2) DO NOT TAKE IT IN. This isn't needed just take the battery out and let it cool down, then do what I said the first time besides the freezer part lol.
  5. #5
    I went through this for a total of 6 Viper replacements between myself and my girl...it got to a point where id notice them sending refurbished underclocked phones claiming it's a "fix" to overheating, what a rip....anyway I escalated the situation myself and direct dialed a corporate executive in Texas, and i filed a complained on the FCC's website, as soon as you hit up the FCC, sprint will call you back..(two gnex's + extended batteries are on the way to my home)
  6. #6
    Lucky... I need that to happen to me
    I'm going to sprint this weekend about the overheating of the battery. What should i say, and if they offer me a replacement should I request a different device.
  8. Thread Author  Thread Author    #8
    This is frequent. So, i am taking it in.
    Quote Originally Posted by progranade View Post
  9. #9
    no don't switch
    Sent from my LG-LS840 using Android Central Forums
  10. Thread Author  Thread Author    #10
    what battery temp is considered overheating the battery says 103 but, my phone gets to 105 tops 130
    - - - Updated - - -
    Don't switch, I do not understand.
    no don't switch
  11. #11
    Bro in all honesty the vipers a piece tell them you don't want another junky viper and that you want a good replacement I got the galaxy Nexus in exchange for my viper and it's a wayyyy better phone. Plus theres an insane amount of development for this device take our advice and make the switch you won't be sorry!
    Sent from my paranoid galaxy Nexus on 4.2.1 which really has no reason to be paranoid unless he never quit smoking.
    Thanked by:
    Justin Cardwell likes this.
  12. #12
    I have too agree with slinkies. The samsung galaxy nexus is alot better. you can do about anything you want with it. The only thing I don't like is there is no sd card on nexus. but man there is alot of storage after the rom installed like 27-28 GB of storage for you too use. There is major defect going on with the LG Viper it seems too me it got worse after ICS update. with performance and battery issues . So if you can go too a service repair center and speak too service manager and if you had too many replacement they will offer u the nexus as a replacement or in some cases they will offer HTC EVO 4G LTE. with Jelly Bean
    If you like my work or If I helped you. Please show some love and click the thanks button or donate here
    Thanked by:
  13. #13
    I never had them replace my viper with another viper after the first one crapped out I just told them I wanted a replacement phone and they offered the gnex or moto photon and photons stuck on gb so gnex it is lol.... Really are they giving evo 4gltes as replacements? Mite have to call and check on that they're pretty nice too idk tho I don't like sense too much kinda like the stock Android feel ya know.
  14. #14
    Quote Originally Posted by slinkies View Post
    I was told I had a choice of motorola photon 4g lte, htc evo 4g lte, Gnex LTE. I picked GNEX. I am happy with the GNEX. I like the idea no bloatware on GNEX Pure google stock and you can do alot more with this device .
  15. Thread Author  Thread Author    #15
    I talked to the technical support and they fixed the wifi and 3g problem, i still have overheating at 100 degrees for streaming music and 110 for playing games. How can i convince the store worker to get me a gnexus?
  16. Thread Author  Thread Author    #16
    This is my first time, no replacements.
  17. Thread Author  Thread Author    #17
    I also have no insurance
  18. #18
    Don't take no for an answer tell them they either replace your phone or your taking your number to Verizon sprint hates that they will give u one call *2 on ur phone immediately tell them up want to talk to a supervisor tech or regular shouldn't matter and PUSH the overheating issue the most that's the thing that will get u the Nexus its worked for like 10 or more of us former viper owners lol just don't get off the phone with them until they say ok tell them ur tired of junk vipers and that you've had problems with it since you got it and don't want another viper that u want a comparable replacement phone
  19. Thread Author  Thread Author    #19
    What is considered overheating, my phone is operating at 110 degrees when watching a movie on 3g.
  20. #20
    Anything over 100 I would consider overheating my old viper topped 128 before I got rid of it averaged 100 to 105 tho with just casual use
  21. Thread Author  Thread Author    #21
    Ya, same here. music is 104 and videos is a lot higher. apps are different time to time. Do you think I am over worried of the problem.
  22. #22
    No that's the reason behind me making the swap it didn't want a phone lighting my hand or ear on fire every time I went to use it lol call*2 and bit** about it they'll give u the gnex trust.
  23. Thread Author  Thread Author    #23
    My viper is average 103 to 110 and on stand by 90. is this normal?
  24. #24
    Quote Originally Posted by n0ve View Post
    I think the phone is a piece of . I had one and it wouldn't last more than an hour or two with absolutely nothing being done. I traded it in for another and same thing. I love the screen and how thin the phone is and call quality was fine but battery life was abysmal. It would die overnight if it wasn't plugged in even though I had gps off, and background data only once an hour or something like that and when I did charge it it would take several hours to complete. It shouldn't take longer to charge a battery than to discharge one.
  25. Thread Author  Thread Author    #25
    The sad thing is it is winter here. I am scared to see how hot it gets when i am outside and it is 98 degrees.
  1. connected to wifi and 3G after root?
    By justinisloco in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 03-30-2011, 02:55 PM
  2. Fascinate signal and 3g problems
    By ljmays in forum Verizon Fascinate
    Last Post: 02-27-2011, 03:29 PM
  3. Optimus Wifi and 3G?
    By heckufaguy in forum LG Optimus S
    Last Post: 11-26-2010, 10:52 PM
  4. WiFi and Bluetooth problem.
    By luckydwg in forum HTC EVO 4G
    Last Post: 07-07-2010, 02:16 PM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
