Results 1 to 6 of 6
    joecobb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default slow charging issue please help!
    Ok so I got the LG Viper about a month ago and two to three weeks after I got it I noticed that almost every time I would plug it in it a notification saying slow charging pops up with a symbol in the notification bar. Can anyone please help me with this? Thanks.
  2. #2
    tommyjoesanders's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: slow charging issue please help!
    Quote Originally Posted by joecobb View Post
    If you are using USB Port too charge then you will see that happen. Really would use a wall charger. using the USB Port too charge has caused alot of problems with battery overheating issues as well. worse using car charger and using google nav. together will really cause future charing the battery issues as time goes on.
    joecobb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am using a wall charger. I plugged it into my laptop once then a few days later I noticed the slow charging icon and ever since then I have noticed that symbol when ever I plug my phone in.
  4. #4
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe thats a firmware issue. and I believe thats why the battery overheating and charging is causing alot of replacement issues of the device
  5. #5
    whymista's Avatar
    Posts
    Global Posts
    560 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this phone for about a week and no matter which source I used to charge it took forever as in several hours.
  6. #6
    BlinkAndYoureDead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this problem recently with my phone. After several days of the problem persisting I looked up some solutions and it was suggested to clean the port and whatever cable was being used. I used a bit of rubbing alcohol and a tooth brush, only just barely dipped and the extra knocked off. That helped only marginally at first, but about a week later the problem went away.
  1. Serious Charging Issues Please help
    By chaosstockdogs in forum Samsung Stratosphere
    Last Post: 11-09-2012, 02:26 PM
  2. Micro sd card in my EVO major issues...please help
    By tech911 in forum General Help and How To
    Last Post: 08-27-2010, 04:16 AM
  3. GMAIL issue- please help!
    By ali.fazal in forum Motorola Droid
    Last Post: 04-15-2010, 12:17 AM
  4. Text issue!!!! Please help
    By jbg21 in forum HTC Droid Eris
    Last Post: 01-22-2010, 10:04 AM
  5. Weird Head Phone (mic) Icon Issue PLEASE HELP!!
    By oracle646 in forum HTC Droid Eris
    Last Post: 12-30-2009, 08:03 PM
