Has anyone had any luck with a hotspot app for the viper? I just got my nexus and I would love to have connectivity wherever I go.
Printable View
Foxfi works great
Hmm...so it does seem to work. Strangely enough when I was looking at it online I swear it said it was not compatible with the viper.
It was not an issue with the viper.
The problem was with ICS.
The dev has since updated the app.
I do suggest you buy the unlock key, without
it you are limited to 15 minutes of wifi
I was able to get it working. Having issue using the proxy server with the foxfi add on, but that is probably a better question for the Dev or the nexus board.
Can anyone confirm FoxFi still works with the latest update?
Yes i use it everyday...on zvi idk about zvjQuote:
Originally Posted by Odinist [Only registered and activated users can see links. Click Here To Register...]
Working here on zvk... just had my 4g tower turned on yesterday so its been fun testing it out using my phone to give my nexus wireless.
Great to hear, thanks!Quote:
Originally Posted by mharrison82 [Only registered and activated users can see links. Click Here To Register...]
