1. someguyatx's Avatar
    Is there any to make the notification LED work on ICS with SMS/MMS? I tried Lightwave, Blink and 3rd party sms programs and no luck.
    I know this forum is nearly dead but figured I would give it a shot.
    06-08-2013 08:24 AM
  2. friedtators's Avatar
    Whatsapp may work. I use noled and could not find android version on website needed
    someguyatx likes this.
    06-08-2013 09:40 AM
  3. someguyatx's Avatar
    I found an old thread here about this topic and editing settings.xml and now the led notification works and flashes green for sms
    The setting is notification_light_pluse and you have to change the value from 0 to 1
    Above Requires root
    Sent from my LG-LS840 using Tapatalk 2
    06-09-2013 03:23 PM
  4. garbb's Avatar
    Where is that settings file located? I assume somewhere in /data/data/? I can't find it.
    06-09-2013 10:31 PM
  5. dark_mirage's Avatar
    find -d 1000| grep settings.xml
    In terminal
    Sent from my XT926 using Tapatalk 2
    06-09-2013 11:05 PM
  6. garbb's Avatar
    I actually found notification_light_pluse in the com.android.providers.settings/settings.db > system sql table, but when I try to edit it with sqlite editor it says "update failed: error 5 database is locked" ...
    06-10-2013 12:16 AM
  7. someguyatx's Avatar
    You must be rooted but I used es file explorer and the root explorer option. From root explorer select mount RW then change /system to RW access so you can edit the settings.xml file. After you are done editing change it back to RO access
    06-10-2013 08:46 AM
  8. garbb's Avatar
    Well I had to search for it since you still didn't actually tell me where it was... Its /system/etc/settings.xml
    I changed it from 0 to 1 and rebooted and sent myself an sms and the light didn't do anything so I guess it doesn't work. This is in ICS; maybe in GB it works?
    06-10-2013 04:30 PM
  9. someguyatx's Avatar
    Im running ICS version ZVK
    Was your screen off when the sms was received? There is no ledif screen is on or phone is plugged in
    06-10-2013 07:35 PM
  10. garbb's Avatar
    Yes the screen was off when the sms was received and I am running ZVK as well. Weird that it didn't work...
    06-10-2013 08:17 PM
  11. someguyatx's Avatar
    That is odd, mine is working for sms, email, gmail. On your sms do you have display message notifications checked?
    06-11-2013 03:01 PM
  12. garbb's Avatar
    Yes display message notifications is turned on. I also have new message popup turned on. Do you have this turned on?
    Just to be sure, is /system/etc/settings.xml the file you edited? And you changed the 0 in this line to a 1?:
    Code:
    <parameter db="system" name="notification_light_pulse">0</parameter>
    06-11-2013 05:47 PM
  13. someguyatx's Avatar
    Yes and yes. I also changed access back to R for that directory after done editing. Not sure if that matters.
    06-11-2013 08:19 PM
  1. Notification LED now available for Captivate
    By NeilQ in forum AT&T Captivate
    Last Post: 08-16-2010, 10:30 PM
  2. Replies: 0
    Last Post: 07-26-2010, 03:59 PM
  3. Anyone else's notification LED stop blinking after a while?
    By Jasonrj in forum Verizon Droid Incredible
    Last Post: 05-07-2010, 07:41 AM
  4. Notification LED
    By Justin89t in forum Verizon Droid Incredible
    Last Post: 04-21-2010, 11:36 PM
  5. Notification LED
    By manningfan10 in forum Motorola Droid
    Last Post: 03-29-2010, 06:50 PM
