off work. i got 4.0.4r1 synced and built with projectopencannibal ics device, the stock ics kernel, and all the samsung stuff like nigel mentioned. i compiled the twrp2.7 recovery with no problem. @josh, i figured i could loki without the aboot and googled for some time, the only results were a loki.zip which loki's att devices strictly, and obviously thee loki readme but the aboot is required. i think coding loki into the build is neccesary and/or dd'ing loki @ the flashed recovery.img? idk. anyway i can i will. @nigel, not sure how savvy yer build skills are, although with cm9 and any cm from my experience. swap frameworks av and native with aosp ics and also androidruntime.cpp, use display-legacy and audio-legacy. could be the samsung references, so if yer starting a new device tree, it may not be necessary. good luck all. i expect to see development lol.
