Results 1 to 3 of 3
    hautaus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LG Vortex KINDLE Brightness Setting Help!!!!!!
    I just got an LG vortex phone, and put some free kindle books on, tired to read, and decided to adjust the font and brightness setting (within kindle app, with open book). I put it on dark background with white text setting and then turned the brightness down. Well, apparently you can turn the brightness down ALL THE WAY and now the screen when I open a book on kindle on my LG vortex is PITCH BLACK, and for all books. Screen is fine and easy to see as soon as I hit the back or homepage buttons, but I cannot read any books now b/c it is absolutely black (tired going into a small, windowless room with closed door, no light, and still the screen is black, can't see anything). Since I can't see, I can't re-adjust the brightness back to normal. ANY SUGGESTIONS!?!??!?! OR even a picture step by step of how to adjust the brightness with an open book and maybe I can approximately blindly on mine to adjust it?????
  2. #2
    mhseris's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ICS - CM9
    Default Re: LG Vortex KINDLE Brightness Setting Help!!!!!!
    Perhaps try uninstalling the app and then reinstalling it - that will probably set it back to default.
  3. #3
    Jared631's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try clearing the APP's cache and data, that may clear the setting. You can access this via Setting > Applications > Kindle > Clear Data & Cache. Hope I could help!
  1. Replies: 4
    Last Post: 04-09-2013, 03:15 PM
  2. lg vortex could use help im not new to flashing
    By head-game in forum LG Vortex
    Last Post: 05-12-2012, 09:42 PM
  3. [Help Needed] GPS & Brightness Settings Reset
    By skurtov in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 04-05-2012, 02:42 PM
  4. screen Brightness Setting Wont Hold
    By seistoes in forum Sprint Epic 4G
    Last Post: 09-03-2010, 11:06 AM
  5. Settings Help
    By mdlissner in forum Motorola Droid
    Last Post: 01-17-2010, 09:02 AM
