DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 4 of 4
    oshapley's Avatar
    Posts
    ROM
    CyanogenMod 9
    Default Problems with booting Vortex into recovery
    I have successfully rooted my Vortex with z4root, and now I wish to install a ROM. (I'm really sick and tired of Froyo.) So I use ROM Manager, obtain a ROM for my phone, and put it into recovery. Yay! The recovery screen shows up, and--- oh wait. The phone reboots by itself and FACTORY RESETS. What the heck!?!? I did everything right, I had what I needed. What's the problem?
    Phone Specs:
    LG Vortex
    Model #: LG660
    OS: Android v2.2.2 Froyo
    ROM: Stock ROM
  2. #2
    jkok's Avatar
    Posts
    Default Re: Problems with booting Vortex into recovery
    you dont have a custom recovery installed search on google "lg vortex custom recovery" theres a good one called gnm 3.0.6 i think it is called, i use it all the time if i have enough time at school ill post a link in this post. if not just google it
    oshapley's Avatar
    Posts
    ROM
    CyanogenMod 9
    Thanks, I installed a custom recovery and finally flashed a ROM!
    New problem: the ROM installed successfully, but it gets stuck at boot every time I power on with a green arrow circling around the Android Man. A little help here?
  4. #4
    jkok's Avatar
    Posts
    the first boot always talk a while. dont worry about it
  1. Boot Loop - into Recovery only
    By exBlackberry in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 10-12-2011, 09:57 PM
  2. Problems with booting from Honeycomb loaded on SD
    By romer3528 in forum Barnes & Noble Nook Color
    Last Post: 05-03-2011, 06:50 PM
  3. Problems with booting to recovery
    By joewknap in forum Virgin Mobile Optimus V
    Last Post: 03-07-2011, 06:33 PM
  4. Problem with converting videos into my portable devices
    By cindy zou in forum The Android Central Lounge
    Last Post: 01-28-2010, 09:11 PM
  5. Problem with converting videos into my portable devices
    By cindy zou in forum T-Mobile myTouch 3G
    Last Post: 01-28-2010, 08:39 PM
