Results 1 to 17 of 17
Like Tree2Likes
  • 5 Post By heycheerilee
  • 1 Post By heycheerilee
    heycheerilee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default (How to fix) Stuck on Setup Wizard
    So, like many others, I attempted to use Clockwork Mod unknowingly that it didn't work. Under 'Flash Clockwork Recovery Mod' it said the current one was already installed so I figured it would be safe to boot into recovery mode. Now, my phone starts up by asking me my Locale, which I select 'English' but after a while of attempting to 'connect to the network' the process stops working and I have to force stop it.
    • I can turn on Wi-Fi from the status bar but only have access to the menu once now that my network is already setup on it
    • Despite being connected to Wi-Fi, the setup wizard still force closes
    • Menu, Home, Back, and Search do nothing
    • The Setup Wizard repeats in a endless loop sort of creating a 'brick' in the sense I'm stuck on startup
    • It seems to not allow me to mount USB as only a charging icon appears with both of my USB cables despite it mounting perfectly before the reboot, so I don't have access to adb or anything like that
    • Trying to hold down button combos like Vol Up and Home do nothing as well
    • The phone was previously rooted
    I greatly, greatly appreciate any help.
    edit: figured it out:
    First, you'll need this. It's the DLLs required for the Vortex along with the stock firmware/ROM which explains 300MB of it.
    1. Install the USB Drivers for your phone if you haven't done so already.
    2. Install LGNPSTv1.2_Store_Version. There's a PDF included but you probably won't need it.
    3. Install the PST Componets. These install the proper .dll files required to make the upgrade process start otherwise LGNPST won't run correctly (trust me, I know.)
    4. Once you've done the above, go to 'C:\LG Electronics\Model\' and add a folder named 'LGVS660
    5. Inside it, place the contents of LGVS660 [DLLs]. All of them. (This was the crucial step I kept missing, and these were hard to find too. Lots and lots of googling!)
    6. You'll need to register the VS660.dll now.
    In Windows Vista/7:
    - a. Start
    b. In search, type CMD
    c. Right click CMD and run as Administrator
    d. Paste this in: regsvr32 "C:\LG Electronics\LGNPST\Model\LGVS660\VS660.dll"
    - If youre on Windows XP,
    a. Start
    b. Run
    c. Run this: regsvr32 "C:\LG Electronics\LGNPST\Model\LGVS660\VS660.dll"
    7. Run LGNPST. It doesn't put an icon in on the Desktop, so run it from the start menu
    8. Connect your phone. It should now recognize it as the model name, VS660. (this may take a few seconds to recognize. ) And if it doesn't and your phone lets you select a mode, it must be in Modem mode.
    9. The DLL should be automatically loaded. If it isn't, select it from the File menu.
    10. Under the Provision tab, select the firmware by clicking the small folder icon next to bin. Since the VS660 has a .tot firmware, you'll need to manually type in the file name: 'C:\LG Electronics\LGNPST\Model\LGVS660\VS660ZV5_02.S5_02.P58006.tot' without the quotes now.
    Final step: Press start. Everything should go fine and your phone should reboot once.
    also, you should probably change your lock code if you don't remember it with this app too, its pretty neat. just sayin
    Don't hesitate to ask any questions. I hope I could help. I rushed this in a hurry, so if you see anything out of place let me know.
    Attached Thumbnails Attached Thumbnails (How to fix) Stuck on Setup Wizard-1225022824_03-1-.jpg   (How to fix) Stuck on Setup Wizard-1225021254_02.jpg
  2. #2
    linuxuser 21's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Stuck on Setup Wizard
    +1 I JUST had this happen. Please help.
  3. #3
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Someone...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm extremely glad to say I myself have found a solution: downgrading/reflashing firmware with LGNPST.
    It's pretty confusing and it took me a good 2 hours to figure out a lot of it, but I will be writing a tutorial on it and I promise to post it back up here as soon as I can! (which may either be later today or later on sunday evening est. sorry for the wait but I won't have access to a PC for the weekend)
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome! I was beginning to wonder if I had a bricked phone.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Edited the first post with a tutorial. Hope it helps!
    Melawetzki likes this.
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Worked flawlessly. Thank you!
  8. #8
    diskdud123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome!! My LG Vortex is back up. Thank you Heycheerilee for your help. I was about recycle the phone because it was not working. Keep up the good work..
  9. #9
    kylesunrise's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This worked great. It un-bricked my phone, but now for some reason I cant activate it on verizon now. Any suggestions?
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kylesunrise View Post
    Can't help you there. When I perfomed the un-brick I never had an active service with them anyways, so I didn't have much to lose. Your best bet seems to be contacting Verizon.
  11. #11
    Phrancheska 1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: (How to fix) Stuck on Setup Wizard
    You are a life-saver!!
    I ran into the same problem after foolishly performing a Factory Reset on my rooted LG Vortex.
    Thank you for these tools with clear instructions!
  12. #12
    dpleydig's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i keep getting a failed to load binary when trying to register the .dll. what am i doing wrong?
  13. #13
    Mus Samsudeen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    plssss helppppp
    what the name of the video
    my phone alcatel ot 983 and its stuck on the setup wizard
  14. #14
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mus Samsudeen View Post
    ...my phone alcatel ot 983....
    This thread is for the LG Vortex and will not work for an Alcatel phone.
    plss what the name of the video for fixing your phone if your stuck on setup wizard
    Video?
  15. #15
    Raaz Ace ARme's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have rooted android 4.2.1 phone and i also have the same problem and i am stuck on it ,what can i do?
    Plz help me
  16. #16
    Romeo Carter's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am currently with the same problem, however, I have a LG ms500 I believe. Any help? Same steps? Thanks
  17. #17
    1980hanks's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a at&t lg vista d631 can't find firmware anywhere can't fix my os can some one please help me send me a download or link
  1. Stuck on "Waiting for Device" trying to unlock bootloader
    By internettoughguy in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 09-21-2016, 03:35 PM
  2. Stuck on sending
    By nickf126 in forum Motorola Droid
    Last Post: 03-01-2012, 03:02 PM
  3. Google Voice stuck on install
    By ckale1 in forum Motorola Droid
    Last Post: 06-04-2010, 08:59 AM
  4. Eris Stuck on Android Screen
    By ericg1840 in forum HTC Droid Eris
    Last Post: 06-03-2010, 10:30 AM
  5. Stuck on sending
    Last Post: 12-28-2009, 11:08 PM
