Results 1 to 1 of 1
- 06-22-2012, 08:24 PM
Thread Author #1
Problem purchasing from play store via web
As the title states I'm having an issue purchasing apps/music from the play store via the web (using Chrome). Every time I confirm a purchase using the web store I get a message about a technical error but it doesn't contain any specific info. However, if I make the same purchase using my device everything works perfectly. Is there anyone else experiencing this issue? Or can anyone offer a fix/workaround? Thanks for any help.
Reply
