Problem after factory reset
meyerweb#CB
Banned
Sep 4, 2009
6,669
8
38
I just did a wipe / factory reset on my original Evo 4G because it had gotten pretty flaky. I also have a Samsung Tablet. Prior to the wipe, the Play Store showed both of my devices and the apps installed on each.
I've done the basic config on the Evo, set up my google account, and synced my google email and calendar. Then I set about to reinstall the apps.
But the play store doesn't show my Evo at all. It shows the tablet, and the apps installed on it, and many of the other apps I ever downloaded show up under '"Other Apps in my library." And when I try to download those (from the play web site), it doesn't show my Evo as an option.
If I access the store from the Evo, it shows some of my apps there, ready to download, but not anywhere close to all of them.
What do I need to do to get the play store to recognize my Evo again?
Thanks!
Lelix2603
