1. GeneJ's Avatar
    When I connect the phone using the USB to my laptop, the laptop does not see it. Also when I had the Droid I had to register it with Motorola to get updates. I have been to the Casio Gz One web sight and I can't find where to register it. Have there been any updates to this phone that might fix this problem?
    08-15-2011 10:23 AM
  2. gpsjunkie's Avatar
    Do you have the proper drivers installed? See here: C771 Drivers - Android Forums.
    AFAIK all updates are OTA. There has been one upate to M050 software.
    08-15-2011 11:51 AM
  3. GeneJ's Avatar
    OK I have tryed to get to the zip file and every time I click on the link it wants me to sign in again and then it will not connect "Access Denided". But I know I'm the forum or I wouldn;t be able to post.
    08-15-2011 05:48 PM
  4. cbreze's Avatar
    If your a member why can't you just go there and forget getting via the link?
    EDIT: just tried to upload it here and after a 15 minute wait for it to load it failed. Dang.
    08-15-2011 06:36 PM
  5. GeneJ's Avatar
    Yes! please send me the link, or the file.
    GeneMyrtleBeach@sc.rr.com
    08-16-2011 04:11 AM
  6. drd1135#AC's Avatar
    Are there a driver for the Mac? I'm having the same problem.
    08-17-2011 12:35 PM
  7. GeneJ's Avatar
    Thanks cbreze that helped
    08-17-2011 03:38 PM
  8. DrD1135's Avatar
    Is there a similar source for Mac Drivers? I couldn't find anything.
    09-05-2011 07:55 PM
  9. tmill404's Avatar
    I need the driver as well, I can't use the link for the same reason. How else can I get it?
    02-03-2012 08:22 PM
  10. rednekshrek's Avatar
    i need the drivers and link not working
    04-23-2012 09:07 PM
