Results 1 to 13 of 13
Like Tree6Likes
  • 6 Post By saxrulez
  • 1 Post By PakiDude
    saxrulez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Kyocera rise wont turn on without charger plugged in / Random Reboots
    Our kyocera rise would occasionally turn off by itself. After turning off it would not power on without the charger being connected. I did some reading on virgin mobiles reviews and saw MANY reviews with the same issue. Well I found the problem/solution.
    The problem is from the battery fitting too loose and losing contact/shifting. This was resolved by cutting a matchbook cover in half and placing it under the battery. The resulting fit is very snug with no wiggle room at all for the battery and we have been a week now without the issue reoccurring. Prior to this we had the issue multiple times a day.
    Hopefully this post helps some people out.
    It isn't ideal that these phones can have this issue, however the solution was very simple and the results have been perfect. Love this phone.
    Edit: 3 weeks and going strong without any reboots.
  2. #2
    beeutifully's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Kyocera rise wont turn on without charger plugged in / Random Reboots
    I want to take this time to say Thank you very much for posting this. I am going to be trying it because my Kyocera Rise just started restarting on it's own.
  3. #3
    PakiDude's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Let me start by saying that I made an account here just to reply to your post.
    Thanks so much. This problem was so annoying. I would put my phone in my pocket and take it out a few minutes later only to find that it turned itself off. This would happen about twice a day. To turn it back on, I would have to remove the battery and reinsert it, but that only worked about half the time.
    Your solution works perfectly! What I did though is that since I didn't have a matchbook handy, I just used a small strip of paper and folded it over about four times and stuck that under the battery. It has been about a month now and my phone hasn't turned itself off.
    Kaity Fast likes this.
  4. #4
    CassiJean's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Seriously needed to thank you. I just bought this phone on Friday, and was already irritated by this issue by Monday. I had to Google it, and to my amazement I'm not the only one with this issue. Thank goodness. This solution is working perfectly as of now. Thank you again!
  5. #5
    ThankYouSoMuch's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had to make an account to say thank you. I bought this phone yesterday and almost returned it. Your trick works like charm.
  6. #6
    josuegg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey I have a question I have a hava a Kyocera rise that just bought it 30 day ago in RadioShack but to the next day the cell phone was heating up and was getting crazy! now I it cannot turns on even with the charger plugged in! and I don't know what to do if I just bought it !
  7. #7
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by josuegg View Post
    Take it back to Radioshack and see if they will replace it for you. That is very odd that this device won't work after 30-days of useage. Worse case is that they refer you to the carrier or manufacturer.
  8. #8
    Kaity Fast's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you so much! This helped out bunches, my phone doesn't give me headaches anymore, AND it gave us an answer for why my phone was acting wacky.
  9. #9
    KallieRenee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Red face Re: Kyocera rise wont turn on without charger plugged in / Random Reboots
    This was amazing! i had just bought this phone 2 days ago i ALREADY returned one to best buy thinking it was just that phone. but when i got home after 3 hours the new cell phone did the SAME THING. it would work fine in my hands and everything but once i put it in my pocket... poof. it quit. so after long searching the web i found your post and i cant express how thankful i am!! wonderful advice and help! after putting the matchbook cover underneath the battery the phone started right up! thanks again !!!
  10. #10
    befree_live's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Omg...The same excact thing is happening to me..i was trying to search on google what to do but haven't found anything yet..I just bought it like last month, and now it wont turn on at all...and when I first got it it got crazy overheated too!!! Like not even the charging little light is turning on..I don't know what to do but if anyone knows what to do pleassseee help
  11. #11
    ChesterShire's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you!
    I was ready to return my phone after having it less than a week.
    Nice quick low tech fix.
  12. #12
    GratefulDroids's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Kyocera rise wont turn on without charger plugged in / Random Reboots
    Am also so glad I found your post. Bought a kyocera rise for my child and within just a few hours of charging up completely, it started shutting off whenever you closed the qwerty keyboard and also wouldn't wake from sleep mode. In both cases, we had to plug back into the charger and push the power button to turn back on. After determining a few hours later that this wasn't some sort of start up glitch, I began searching online for answers. Your post described exactly what we were experiencing, and after also cutting a 'shim' to support the battery, we are back in business! Has been fourteen+ hours now and so far no more issues. Will keep an eye on it to make sure the problem has indeed been resolved, as we are still in the grace period to return the phone if need be, but so far so good. I have a happy camper again and that's more than worth the effort to set up an account here to reply to say thanks!
  13. #13
    Seanda Lambert's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just wanted to say thank you!! I've had this phone just under a week, and 3 days ago was starting to have this problem, multiple times daily. I googled, and saw your post and tried this... and, it worked. Keeps in my pocket now and doesn't shut off I love my phone, soo, soo much, thank you!!
  1. WiFi Turns On Automatically When Charger Plugged In
    By fuzmeister in forum HTC Droid Eris
    Last Post: 02-19-2015, 11:30 AM
  2. Evo wont turn on
    By osakran in forum HTC EVO 4G
    Last Post: 06-25-2010, 08:14 PM
  3. phone wont turn on
    By jnadelman in forum HTC EVO 4G
    Last Post: 06-22-2010, 07:49 AM
  4. phone wont turn on!
    By jd in forum Motorola Cliq and Dext
    Last Post: 06-12-2010, 02:41 PM
