1. cassandravanhuss's Avatar
    I rooted my kyocera hydro and downloaded ezunlocker to unlock bootloader. Now my phone is stuck in bootloop with no recovery options. It wont even give me the option to factory reset. I have tried the power button + vol down and it proceeds to the boot loop!!! WHAT DO I DO HELPPPPPPPPP
    Nick Havok likes this.
    02-05-2014 03:03 PM
  2. Nick Havok's Avatar
    i just had boot loop that i thought killed it. i was going to break just like all the others. i tried everything. i have a cricket -old skool- hydro. turning on into boot loop screen would go from black to white(hydro screen) then green cricket screen than turn back off. i tried ALL the button presses and options... THEN I found a website that said just holt the power button and volume down for 15 seconds. Ill be damnded if the little android dude didnt show up and fix my poot. Thats all it took. WARNING: will erase EVERYTHING but way better than a brick or broken plastic. Hope this works
    02-25-2014 09:52 PM
  3. MichiLater's Avatar
    I have the same problem. when i try to boot into recovery mode it makes past the android splash to kyocera logo. then an androids image loading. the immmediatly shuts back off. without giving recovery options. should i say **** it and get a new phone?
    12-18-2015 05:44 PM
  1. Stuck in flight / airplane mode
    By tnmok in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 10-05-2015, 10:04 AM
  2. Outlook contacts no longer sync
    By cjb44 in forum AT&T Galaxy S III
    Last Post: 04-15-2014, 03:34 PM
  3. Using S3 in the car- Music
    By coachpelkey in forum Sprint Galaxy S III
    Last Post: 02-05-2014, 02:42 PM
  4. Replies: 0
    Last Post: 02-05-2014, 12:37 PM
  5. Phone function with headphones plugged in...
    By Btravelen in forum Motorola Droid MAXX
    Last Post: 02-05-2014, 12:16 PM
