1. maxc2727's Avatar
    I also Just purchased ( very cheaply lol) a SoftwinerEvb 4.0.4 tablet Kernel Version 3.0.8+ Build number nuclear_evb-eng 4.0.4 IMM76D20130921 test-keys. The problem I am having is getting the tablet to stay idle more than a minute. After that the screen goes blank and I have ti hit the power button to get the screen back. Also how do I download apps to this tablet....Thanks for your input in advance.?
    10-16-2013 03:03 PM
  2. B. Diddy's Avatar
    Go to System Settings/Display, and look for an option for Sleep. You can adjust how long the tablet will remain idle before turning the screen off.
    Apps are best installed from a legitimate app store like Google Play or Amazon Appstore. Not all Android devices are approved for Google Play--since you have an off-brand device, it might not be available to you. It's also not available in every country--where do you live?
    Your device probably came with a link to some kind of app store--look for a shortcut to something that sounds like a Market. You could probably also install Amazon Appstore by opening your device's browser and going to www.amazon.com/amazonappstoreapp, and following directions from there. Before you install, make sure you go to System Settings/Security, and check the "Unknown Sources" box (if there is one), which allows installation of apps outside of the official Google Play Store.
    maxc2727 likes this.
    10-16-2013 03:34 PM
  3. maxc2727's Avatar
    Thanks for your help B Diddy ! That was very helpful !
    B. Diddy likes this.
    10-17-2013 12:47 AM
  1. HTC One - Issues booting after full wipe
    By nstirton in forum HTC One Rooting, ROMs & Hacks
    Last Post: 10-06-2014, 04:01 AM
  2. Galaxy S3 I9300 - Need help with VoIP apps
    By Nurega21 in forum Samsung Galaxy SIII I9300
    Last Post: 10-22-2013, 08:27 PM
  3. Help me with this "4gb internal flash" stamped on the box.
    By Figueroa4 in forum General News & Discussion
    Last Post: 10-17-2013, 07:23 PM
  4. A reliable Notes app from Android to sync with my Mac...
    By Ludatyk in forum General Help and How To
    Last Post: 10-16-2013, 11:55 PM
  5. Can anyone help me out? Not bad at software, just new to Android.
    By William Hyde1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-16-2013, 02:03 PM
