After updating to release 6.0.1 Marshmallo my Samsung Galaxy tab s 10.5 has no wifi. Wifi will not turn on. I have done the factory reset several times but wifi still will not turn on. Is anyone else having this problem..???
Have you tried a cache clear in recovery?
First try shutting off bluetooth, see if you have wifi. There is reports of not working with bluetooth on. After goto settings, backup and reset, reset network settings. I don't know if after putting bluetooth back on it will work. But try. Samsung has a problem with it, they are aware. Reinstall hasn't corrected it.
