1. ronclone's Avatar
    Guys i don't know why, but suddenly I'm not getting any media-apps sound from the loudspeakers... When I restart the phone it works for a few seconds (when I unlock the phone for the first time it works) then when is not Working and I press the volume up key it acts like I have an earpiece plugged in (gives me the too loud for too long warning)
    Anyone have a clue? 4.4.3. Unrooted here... Only "mod" I've done is L keyboard and WhatsApp+...
    07-26-2014 04:20 PM
  2. Golfdriver97's Avatar
    Have you tried a reset? There might be a cached data conflict somewhere.
    08-27-2014 03:24 PM
  3. Shanker Parepalli's Avatar
    I am also getting the same problem. It automatically works fine after two or three days. And few days after same problem,, speakers not working.. Right now speakers not working and tried all tricks no use
    12-01-2014 12:48 PM
  4. ImogenF's Avatar
    After much research, I have discovered that the answer to this is simple, it is a bad connection in the loudspeaker. Take the back off the phone, and press quite hard around the back of the loudspeaker/bottom of the battery area. Within a couple of seconds the speaker came back to life and is still working fine. I had lost all alarm tones, notification tones, incoming call did not ring and loudspeaker did not work, but all good now.
    01-19-2015 05:55 PM
  5. Amruth Krishna's Avatar
    this works...thanks a lot
    02-17-2015 11:27 AM
  6. charliepowell47's Avatar
    Hi ive got the same problem, when i press round the battery area amd sound comes on. But wont stay on any suggestions
    04-01-2015 07:17 AM
  7. Shekhar Tanwar's Avatar
    That worked... Thanks.
    07-29-2015 03:13 AM
  8. Karthik Rumesh's Avatar
    Wow that works very Useful
    11-05-2015 03:01 AM
  9. HeathenamI's Avatar
    Thank you so very much. This worked for my phone.
    11-29-2015 05:09 PM
  10. rameshp6's Avatar
    Hey Thanks For Your Suggestions It Really Worked...
    05-02-2016 03:26 AM
  11. kerrylaw's Avatar
    A lot of Moto E owners have run into a bug where the sound completely stops coming out of the speaker, or it comes out incorrectly. Audio continues to work correctly through headphones. This was caused by a bad connection between the speaker and the main board. If you smack. tap rap or bend the phone, somtimes the sound will work. Here is the cause and here is how I fixed it….
    Step 1) Power down phone.
    Step 2) Remove the 14 screws from the back cover. These are “hex or spline” screws, but if you don’t have the correct tool, a fine “straight” screw driver will work.
    Step 3) Open the phone and carefully fold the rear cover over. Be careful not to break or stress the battery cable.
    Step 4) Locate the speaker pads on the main board and clean them. Alcohol is good. Clean the pads and their respective fingers on the back cover. This is where the fault lies. These pads get dirty from micro dust and fail to make good contact with the fingers. That is why “banging” or “smacking” the phone on the back, at this location, temporarily fixes it.
    Step 5) While you are at it, clean the pads and fingers for the headphone jack also.
    Step 6) reassemble! Should hear sound as designed.
    belodion likes this.
    09-29-2016 04:26 PM
  12. sagar_shah's Avatar
    Dude you just saved my phone. Thanks a lot
    11-14-2016 12:51 PM
  13. Suriyawwe's Avatar
    12-12-2016 11:28 AM
  14. Suriyawwe's Avatar
    Thank you 100000000000times man... same problem with moto g3...you are a life saver....thank you very much
    11110 likes this.
    12-12-2016 11:29 AM
  15. Srini0815's Avatar
    That's working , thanks a lot man
    12-18-2016 08:10 AM
  16. 11110's Avatar
    WOW ITS REALLY WORKING, AM FACING LAST FEW DAYS same problem, I got solution , it's working now 😀
    03-04-2017 07:11 PM
  1. De;te multiple e-mails on moto-x
    Last Post: 03-09-2015, 08:01 PM
  2. WTS: Motorola Moto X
    By charlyee in forum Marketplace Archive
    Last Post: 08-02-2014, 08:48 PM
  3. Samsung galaxy s advance turon on problem
    Last Post: 07-29-2014, 02:57 PM
  4. moto g: using contacts from sim card
    Last Post: 07-26-2014, 05:56 PM
  5. Wifi help
    By jun sal in forum Samsung Galaxy Tab 3
    Last Post: 07-26-2014, 05:52 PM
