Results 1 to 12 of 12
    Ding Dong2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Moto G: Antenna position - signal issues when holding phone
    I am having problems with phone signal. I checked O2 coverage checker I am in a good zone.
    At the moment I am connected to WiFi and the mobile signal is at 2 bars. However, as soon as I put down my phone I get full bars. But as soon as I pick up my phone it drops. I usually hold my phone with 2 hands (typing position)
    However, when I enable mobile data my mobile bars go up to 3 and get 5mbps download.
    Could it be because its relying on WiFi ?
    Would a hard case help with the signal? I am thinking of buying of a Ronnie slim case for the moto g.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,056 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Antenna posisition.
    Quote Originally Posted by Ding Dong2 View Post
    Welcome to the forums.
    Did you buy this through your carrier? If so, I would consider an exchange.
  3. #3
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also check with your carrier that it is classed as a 4G device and not only a 3G device. Some carriers are not grouping the Moto G with 4G service because it doesn't have LTE.
    HSDPA, 21 Mbps; HSUPA are the only 4G bands the Moto G has
  4. #4
    Connervt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Reborn & Quattrimus
    You're holding it wrong.
    /* channeling Steve Jobs */
    Ding Dong2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its like the iPhone 4 problem. Would a case fix the issue?
    Holding it wrong. How would I hold it right then?
  6. #6
    MotoClive's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe it was just a joke on Apple
    Ding Dong2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there any known fixes? Anyone else having this problem or just me?
  8. #8
    MotoClive's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Moto G: Antenna position - signal issues when holding phone
    Seems it is just you
  9. #9
    shmotog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This happens with me as well. This is normal, there is nothing to worry about here at all. I believe the position of the antenna is towards the bottom of the phone, thats my own humble opinion though, so don't quote me on that. There are places where if I put it in my lap and cover it on the bottom part with my palm, signals go altogether.
    Signal strength depends ona lot of things. I find 2G signals work better, at least in my area.
  10. #10
    PiggyMiddle's Avatar
    Posts
    Global Posts
    547 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    May not be quite the same thing, but I am using my G as a wifi hotspot. If I have the screen face up I get 3-bars of 4 on the laptop wifi, if I have the good camera facing up I get the full 4 bars on the laptop. Still a good connection, but there is a difference.
  11. #11
    shmotog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PiggyMiddle View Post
    Keep the phone like this, always. :P
  12. #12
    Roobed Trejo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same problem, did you find a solution ??
  1. External wifi booster antenna
    By AlanPent in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-28-2014, 05:34 AM
  2. Lg G2's ugly looking antenna.
    By crackbaby001 in forum LG G2
    Last Post: 11-22-2013, 06:27 PM
  3. Antenna question
    By TomW093 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 11-08-2013, 10:54 PM
  4. Location of LTE/CDMA antennas
    By npharper in forum Verizon Galaxy Note 2
    Last Post: 09-25-2013, 08:56 PM
  5. Replies: 3
    Last Post: 09-11-2013, 01:50 PM
