1. GravityMan's Avatar
    Is it supposed to come on while it charges?
    Sent from my XT1033 using Tapatalk
    01-28-2014 07:24 AM
  2. nessinhaw's Avatar
    noooope! but i wish i would ):
    sent from my Moto G <3
    01-28-2014 09:30 AM
  3. Potati's Avatar
    If you are rooted, you can use an xposed module called Moto Guide to make it come on.
    Sent from my XT1034 using Tapatalk
    01-28-2014 09:35 AM
  4. GravityMan's Avatar
    So it actually doesn't and u can confirm - I am not the only one with a led light that does not come on while charging? Thanks on advance.
    01-28-2014 02:19 PM
  5. still1's Avatar
    Can you not use light flow lite application???
    dont have a G but this app could get you what you you are looking for
    01-28-2014 02:26 PM
  6. GravityMan's Avatar
    led works....but I mean while charging....
    01-28-2014 02:28 PM
  7. still1's Avatar
    yes with light flow Lite app you can do that. make it blink while charging
    01-28-2014 02:37 PM
  8. Vorbaciov's Avatar
    normally, it should, if the option is activated in settings. and in my case, sometimes it does, sometimes it doesn't. that's how I got here...
    01-29-2014 04:27 AM
  9. GravityMan's Avatar
    And how do u activate it in the settings?? Which menu is it on the Moto G??
    01-29-2014 04:28 AM
  10. Vorbaciov's Avatar
    I have no idea, i'm talking from a S4 owner point of view...
    01-29-2014 07:39 AM
  11. GravityMan's Avatar
    I see.. Anyone who owns a moto g?
    01-29-2014 07:40 AM
  12. davekelly12's Avatar
    Yes, I got the Moto G Dual Sim XT1033. The Light Flow lite application allows you to get the LED to flash while charging. I tried to make it always on but the flashing didn't stop.
    In case the LED doesn't come on, install the Notification Light Widget by Motorola to enable the LED.
    Note: Looks like Moto G has only support for White color LED.
    01-31-2014 12:46 PM
  13. GravityMan's Avatar
    Do you have KitKat 4.4.2 yet?? Since it is dual sim?
    02-08-2014 11:48 PM
  14. GravityMan's Avatar
    And if you do....how is it? Screenshots on the dual SIM version?
    02-08-2014 11:49 PM
  15. Khai Tran1's Avatar
    So, is the light supposed to flash or turn on while charging? Forget about applications do that, does everyones Moto G while plugged in have a light or not?
    07-15-2014 05:21 PM
  16. Sizzers's Avatar
    Mine doesn't but that's of no concern.
    If you do want an app for that then personally I much prefer Light Manager over Light Flow.
    I also use an app called Battery Notifier BT Pro, which amongst its many extremely useful functions it lets you set an alarm for when your phone has charged. Note I didn't say FULLY charged as you can also set the alarm to go off at any pre -determined charge level, which in my case is 90 per cent.
    IIRC these functions are available in the free version, but either way a highly recommended app IMO.
    Sent from my XT1032 using AC Forums mobile app
    07-16-2014 03:50 AM
  1. LG G2 assigning different notification tones
    By Hand_O_Death in forum LG G2
    Last Post: 04-11-2016, 09:38 AM
  2. Replies: 4
    Last Post: 03-11-2014, 02:54 PM
  3. when I connect to internet , I see notifications about some applications
    By mfaridi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 05:09 AM
  4. make message notification show name
    By villa513 in forum Samsung Galaxy S3 Mini
    Last Post: 01-27-2014, 03:13 PM
  5. Editing LectureNotes while playing audio
    By V5RED in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-27-2014, 01:57 PM
