1. AM_SOS's Avatar
    Hi all,
    This one is about the "battery meter" and how one can get it to reset. I recently upgraded to KitKat and the phone/battery are working really well.
    I have also started to use a 80 % to 40 % charging cycle/day which is supposed to delay battery wear.
    However, it's irksome to see that every time I take the phone off the charger, the battery meter doesn't reset and carries over the readings from the past few charges.
    I notice that it starts from zero only when I charge the battery beyond the 90 % limit.
    Is there any way to reset the battery meter so that it starts from a zero reading irrespective of the upper charge limit of the battery?
    Thanks!
    03-22-2014 12:51 AM
  2. Golfdriver97's Avatar
    I don't think there is a way to change that. That is coded deep in the OS itself.
    03-22-2014 09:01 AM
  1. hello, I'm new to forums
    By jog62003 in forum Introductions
    Last Post: 04-04-2014, 11:15 AM
  2. LG G2 won't connect to app after update
    By tonio9109 in forum T-Mobile LG G2
    Last Post: 03-23-2014, 02:51 PM
  3. note 3 battery dying prematurely
    By Rustys Raw Bar Estero in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-22-2014, 07:35 PM
  4. How do i use my freshly rooted nexus 10 as a USB mass Storage device for the xbox 360?
    By Justin McIntyre in forum Nexus 10 Rooting, ROMs, & Hacks
    Last Post: 03-22-2014, 12:07 AM
  5. How Can I Get Downloads to Show UP on my HD?
    By thailen in forum ASUS MeMO Pad HD7
    Last Post: 03-21-2014, 11:42 PM
