1. Chayan Bahl's Avatar
    I bought a moto g last week. It is working fine but I noticed this weird battery issue. I charged my phone but it stopped at 97%. On asking customer care they asked to try a different charger which I did but now it stopped at 93%. Is this some battery problem and should I request for a handset exchange? Any help please.
    04-19-2014 09:29 AM
  2. ColbyJvonBrown's Avatar
    Yes it's a battery issue I've had it before on my Samsung Galaxy Ring, and ZTE Awe. It doesn't think it can charge to 100% because it isn't utilizing the 3% which means it thinks it only has a 97%-93% compacity. So you need to get a replacement and if it isn't covered by warranty then get a Walmart protection plan they'll replace it. Hope this helps!!!
    04-19-2014 12:15 PM
  3. MotoClive's Avatar
    You could try letting it discharge until it turns off, then charging it without restarting till fully charged. This may retune its battery level readings.
    04-19-2014 12:58 PM
  4. Chayan Bahl's Avatar
    I tried the discharging and recharging but it doesn't help
    So I have ordered a replacement.
    But if anyone has any other tricks to solve it then please help.
    04-20-2014 12:21 AM
  5. ColbyJvonBrown's Avatar
    I have to send mine in because the battery goes from 100% to 95% in 5 minutes!! Then if I use it the battery depletes very quickly!!
    04-20-2014 10:20 AM
  1. Replies: 6
    Last Post: 07-21-2015, 02:02 PM
  2. Those getting great battery life, what is your brightness set to?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 04-24-2014, 12:07 AM
  3. Anyone else has a charge port that is extremely tight?
    By perithimus in forum Samsung Galaxy S5
    Last Post: 04-21-2014, 06:33 PM
  4. Replies: 4
    Last Post: 04-20-2014, 12:01 PM
  5. Replies: 2
    Last Post: 04-19-2014, 06:05 PM
