1. hrazib's Avatar
    After upgrading in 4.4.4, I can't on battery saver in Battery settings. When I'm trying to on the battery saver and press the back button to go another window it just shut off automatically. What the hack?
    Did anyone in xt1033 or another model user face this problem, or it just me the Columbus discovered the Bugs.
    Sent from my XT1033 using Tapatalk
    08-04-2014 12:53 PM
  2. cgardnervt's Avatar
    Did you try powering down the device then resetting it?
    08-04-2014 01:16 PM
  3. hrazib's Avatar
    Yap, not working.
    08-04-2014 01:20 PM
  4. Javier P's Avatar
    Did you disable Moto Care or Moto Assist?
    Moto G from ACF
    hrazib likes this.
    08-04-2014 01:51 PM
  5. hrazib's Avatar
    Thanks guys, it is Moto Assist I disabled it. Why it required?
    08-04-2014 09:12 PM
  6. Javier P's Avatar
    I had the same problem and decided to keep M assist enabled. It doesn't use much battery. I can see from your signature that your phone is a Moto G dual sim, same as mine. Don't worry too much about the battery. Even being a heavy user is going to make it though the day with no problem.
    I'm a heavy user and my average (Gsam) is 30 hours and more than 7 SOT.
    Moto G from ACF
    hrazib and anon8380037 like this.
    08-05-2014 07:36 AM
  1. Samsung S4 not charging/turning on
    Last Post: 04-26-2015, 01:57 AM
  2. Advice on accessories needed vs not needed
    By android jack in forum HTC One M8 Accessories
    Last Post: 09-08-2014, 02:19 PM
  3. battery drain fix
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 08-08-2014, 12:07 PM
  4. Htc one x not holding charge......
    Last Post: 08-05-2014, 06:44 PM
  5. sign in
    By Unregistered in forum Ask a Question
    Last Post: 08-04-2014, 12:44 PM
