Results 1 to 4 of 4
    Default My Moto G's phone case creaks in top right - please help
    My 9 month old Moto G clicks/creams if any strain is put on the top right corner. I've taken off the back and the problem is for the back part, not the body. Will getting a new back fix the issue?
  2. #2
    Default Re: My Moto G's phone case creaks in top right - please help
    Ear plugs might be cheaper.
    Nope, this is to do with creaking in the phone case - ear plugs are off-topic...
  4. #4
    You use the cheap foam roll up to fit in your ear type and shave small slivers off and use one the right size/shape in near the offending tab/seam/gap and put the back on. The sliver of foam will form fit into the tab/seam/gap that is creaking and stop the noise. Not sure how off topic that is but it is a DIY fix.
    The trick is finding the two points of contact that are rubbing and making the creak sound and getting the foam between them.
  1. Google Voice Voicemail Help
    By alphabets in forum Moto X (2013)
    Last Post: 08-30-2014, 08:02 AM
  2. how can i go back to the stock rom in LG G2 verizon
    By alejandro plata in forum LG G2 Rooting, ROMs, & Hacks
    Last Post: 08-10-2014, 08:47 AM
  3. I factory reset my flashed Galaxy S3..why won't it work??
    By Misty Baker in forum Samsung Galaxy S3
    Last Post: 08-09-2014, 01:54 AM
  4. WiFinot connectin in Karbon A7 Androd ver 2.3.6
    By Sanjeev Taneja in forum Ask a Question
    Last Post: 08-08-2014, 04:35 PM
