My Moto G's phone case creaks in top right - please help
RJDG14
8
My 9 month old Moto G clicks/creams if any strain is put on the top right corner. I've taken off the back and the problem is for the back part, not the body. Will getting a new back fix the issue?
zedorda
2,594
178
You use the cheap foam roll up to fit in your ear type and shave small slivers off and use one the right size/shape in near the offending tab/seam/gap and put the back on. The sliver of foam will form fit into the tab/seam/gap that is creaking and stop the noise. Not sure how off topic that is but it is a DIY fix.
The trick is finding the two points of contact that are rubbing and making the creak sound and getting the foam between them.
