My 18 month old Moto G2's battery is draining by 10-15% every 20 mins and it takes about 7-8 hours to charge from 10% to 100%
The phone also gets very, very hot even in standby mode even with Data/Wifi/Bluetooth disabled and when not in use.
I had installed Ampere app and here are the stats:
Discharge rate/sec: 400-690 mA
Charge rate/sec: 50-70 mA
I had tried the following:
Some screen-shots:
Is it a hardware issue ?
- Reboot
- Safe Mode
- Cleared the Cache Partition
- Checked for any battery draining apps
- Removed the SD card
- Reset App preference
- Removed all SIM cards
- Switched off the phone and plugged it for charging and it took 2 hours to go from 65% to 85%
Some screen-shots:
