Results 1 to 14 of 14
    Default LED notification while charging....
    Is it supposed to come on while it charges?
    Sent from my XT1033 using Tapatalk
  2. #2
    Default Re: LED notification while charging....
    noooope! but i wish i would ):
    sent from my Moto G <3
  3. #3
    If you are rooted, you can use an xposed module called Moto Guide to make it come on.
    Sent from my XT1034 using Tapatalk
    Quote Originally Posted by GravityMan View Post
    So it actually doesn't and u can confirm - I am not the only one with a led light that does not come on while charging? Thanks on advance.
  5. #5
    Can you not use light flow lite application???
    dont have a G but this app could get you what you you are looking for
    Fancy A Break From Your iPhone? Have an Android Kit Kat
    Quote Originally Posted by still1 View Post
    led works....but I mean while charging....
  7. #7
    yes with light flow Lite app you can do that. make it blink while charging
  8. #8
    normally, it should, if the option is activated in settings. and in my case, sometimes it does, sometimes it doesn't. that's how I got here...
    Quote Originally Posted by Vorbaciov View Post
    And how do u activate it in the settings?? Which menu is it on the Moto G??
  10. #10
    I have no idea, i'm talking from a S4 owner point of view...
  11. Thread Author  Thread Author    #11
    I see.. Anyone who owns a moto g?
  12. #12
    Yes, I got the Moto G Dual Sim XT1033. The Light Flow lite application allows you to get the LED to flash while charging. I tried to make it always on but the flashing didn't stop.
    In case the LED doesn't come on, install the Notification Light Widget by Motorola to enable the LED.
    Note: Looks like Moto G has only support for White color LED.
  13. Thread Author  Thread Author    #13
    Quote Originally Posted by davekelly12 View Post
    Do you have KitKat 4.4.2 yet?? Since it is dual sim?
  14. Thread Author  Thread Author    #14
    And if you do....how is it? Screenshots on the dual SIM version?
  1. Replies: 4
    Last Post: 03-11-2014, 02:54 PM
  2. when I connect to internet , I see notifications about some applications
    By mfaridi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 05:09 AM
  3. LG G2 assigning different notification tones
    By Hand_O_Death in forum LG G2
    Last Post: 01-28-2014, 12:08 PM
  4. make message notification show name
    By villa513 in forum Samsung Galaxy S3 Mini
    Last Post: 01-27-2014, 03:13 PM
  5. Editing LectureNotes while playing audio
    By V5RED in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-27-2014, 01:57 PM
B
