Results 1 to 5 of 5
    Default Battery Drain while mounting a USB drive
    Is this normal? I mean my battery went from 90 to 60 in an hour while watching a movie from the mounted USB disk at the lowest brightness. Its the first time I've tried the OTG functionality on my Moto G, so can't seem to know if this is normal.
    Any help will be appreciated.
    Sent from my XT1033 using AC Forums mobile app
  2. Thread Author  Thread Author    #2
    Default Re: Battery Drain while mounting a USB drive
    Plus now I'm getting an annoying notification that doesn't go away. What to do?
    Attached Thumbnails Attached Thumbnails Battery Drain while mounting a USB drive-1405522615008.jpg
  3. #3
    Not sure if it's entirely normal, but it's expected. When using OTG, if not powered by an external USB port, it draws the energy from YOUR phone, and USB sticks/hard drives are not usually designed to work with low power, and they do take a toll.
    Thank you for your help
  5. #5
    Also, I know it's not ideal, but the less files you have on the drive you're using the better. With more files, your device spends more time and energy scanning them.
  1. Sdcard using 41% of battery!
    By Perry Moore in forum Google Nexus 7 Tablet (2013)
    Last Post: Yesterday, 10:41 PM
  2. Updating worth while?
    By CompuDino in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-16-2014, 09:43 AM
  3. Note 3 never sleeps, battery drains
    By grumbledook in forum Samsung Galaxy Note 3
    Last Post: 07-23-2014, 04:25 PM
  4. Google plus using a lot of battery
    By Lucy Davies in forum Samsung Galaxy S4
    Last Post: 07-17-2014, 09:41 AM
  5. BBC Weather App Battery Drain
    By belodion in forum Samsung Galaxy Note 3
    Last Post: 07-16-2014, 06:29 AM
