Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By mawells787
    Default Battery saver won't stay on
    I enable it in the battery screen, click refresh, and its back to off.
    Tried a reboot and hasn't helped. Anyone else have this problem?
  2. #2
    KWKSLVR's Avatar
    Posts
    Global Posts
    588 Global Posts
    Default Re: Battery saver won't stay on
    Nope, I can't replicate the problem either. Google how to boot into stock recovery and wipe cache. Maybe that'll help?
  3. #3
    The tap to turn it on does turn it on but doesn't show. So when it shows off, tap it, then go back a screen and then back into battery stats and it'll be enabled.
  4. #4
    Default
    Hi I just researched this problem last night. If you're like me you've disabled as many apps as you can. In the process you have disabled moto assist. Battery saver for whatever reason relies on it. Just enable moto assist go to the app store and update it and battery saver will work.
    Thanked by 2:
    shmotog likes this.
    right on. thanks dude
  6. #6
    Same issue i was facing, suggestion by mawells787 has worked out, thank you
  7. #7
    sting7k's Avatar
    Posts
    Global Posts
    3,619 Global Posts
    ROM
    Stock JB 4.2
    Not to hijack the thread but what does this feature do? I turned it on in the settings; and it stays on. But I haven't been able to find any info on what it actually does. Anyone know?
  8. #8
    Default
    Courtesy of anandtech.
    "One thing I will note is that the Moto X does have a power saver mode, but it appears to just disable background sync and put the data connection to sleep aggressively. It doesn't change the governor so that the max CPU frequency is lower (say the 1.1 GHz state) like a lot of other OEMs power savers do, which seems like a missed opportunity. "
    Source: http://www.anandtech.com/show/7235/moto-x-review/6
  9. #9
    davidnc's Avatar
    Posts
    Global Posts
    7,721 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    Quote Originally Posted by sting7k View Post
    Here ya go :
    "The Moto X's battery saver is also very impressive. If you enable it, it comes in when you drop to 15 percent charge. It disables background data use, meaning less push notifications for your email and social networks, and also institutes aggressive screen dimming and time outs.
    It does great work milking that last bit of charge for you. With battery saver enabled at fifteen percent, we got over two hours of battery life before reaching one percent."
    "The Moto X will ask you if you want to enable this feature when your phone gets below 15%, but if you keep it on all of the time the phone will easily get you anywhere from 24-28 hours of battery life, depending on your usage. This battery saver mode causes the phone to check for notifications far less frequently, which will allow the phone to consume significantly less power during the times you aren’t actively using it."
    Link info is from :
    http://androidforums.com/motorola-mo...ery-saver.html
    Thanked by:
  10. #10
    Quote Originally Posted by mawells787 View Post
    thank you
  11. #11
    I have Moto assist disabled & battery saver on. Seems to work fine?
  12. #12
    I agree that battery saver won't stay on
  13. #13
    davidnc's Avatar
    Posts
    Global Posts
    7,721 Global Posts
    ROM
    Quote Originally Posted by fiat3192 View Post
    Did you see post #4 ? To read that poster's ideal ?
    sent from my Moto X , Android Central Moderator
  14. #14
    turn on moto assist app, may be you have disabled it. after turning this app on you will be able to turn on battery saver.
  1. G Pro does not boot/charge. Menu+Back button flashes when on USB
    By Bram vd vecht in forum LG Optimus G Pro
    Last Post: 10-25-2014, 12:08 PM
  2. Updated to 4.3, phone freezes on Samsung Galaxy S3 Splash Screen
    By RemD0G in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 02-02-2014, 11:51 PM
  3. Deleting Multiple SMS on same Thread
    By Viruba in forum Android Apps
    Last Post: 12-13-2013, 10:34 AM
  4. New Gmail Update 'deletes' emails on Server when 'Never' delete is selected
    By Bad Drivers in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-09-2013, 11:18 PM
  5. Badge Notification Missing on Email Icon
    By fox-mulder in forum Samsung Galaxy S4
    Last Post: 12-09-2013, 06:23 PM
