1. tmann202's Avatar
    I am about to pull the trigger on a Moto X but just wondering what KitKat does for it. I've seen a few reports here of it reducing battery life. If I order now, will it be included or will it need to be updated? Is this easy to do? Will it update automatically, or can you choose to stay with a previous version? If you can choose not to use it, would anyone recommend NOT using it?
    Thanks for any help!
    02-02-2014 12:29 PM
  2. still1's Avatar
    just update before entering your gmail id... you would have no issues... it will be an ota update in settings
    02-02-2014 12:58 PM
  3. gtg465x's Avatar
    Battery life is the same for me with KitKat. It's great.
    02-02-2014 12:58 PM
  4. mumfoau's Avatar
    Mine had KitKat when I bought it and it consistently lasts throughout the awake hours of the day with plenty battery life to spare!
    A895 likes this.
    02-02-2014 04:33 PM
  5. elvisgp's Avatar
    Battery lasts the whole day for me, and I'm on kitkat. I updated to it right when I got the phone though.
    02-02-2014 07:22 PM
  6. cdmta's Avatar
    Mine also came with 4.4. Got the phone yesterday. Mine has been lasting all day with some to spare also.
    02-02-2014 07:45 PM
  7. anthony2558's Avatar
    KitKat does not reduce battery life like some say out their. If it does there is some type of underlying problem that needs to be addressed.
    Tapatalk via Moto X
    02-02-2014 08:07 PM
  8. jcg5862's Avatar
    I updated when I got mine two months ago. Battery life lasts all day. I charge each night anyway, so works for me. Not an issue.
    Posted via Android Central App on my Moto X
    02-02-2014 09:30 PM
  9. clankfu's Avatar
    Battery life is the same or even slightly better for me on 4.4.
    02-03-2014 03:56 AM
  10. mumfoau's Avatar
    I do the same. Charge over night while powered off.
    02-03-2014 05:54 AM
  11. shelbylido's Avatar
    I installed Battery Doctor 2 days ago and I am 21 hours now on original charge since installing app.
    02-03-2014 07:03 AM
  12. PiggyMiddle's Avatar
    It is also a good idea, well, to me anyway, to go through the Apps and "Force Stop" and "Disable" stuff you do not need or want.
    The stock Moto/Android apps are not deleted and they can be restarted if needed later. The re is a bunch of stuff like HP Printer, Moto Care, Play Services etc that is running and eating power.
    Take some time and go through the "Settings > Apps" and stop and disable stuff. Then swipe left for "Running" and do the same there.
    If you want to restart a disabled stock App then swipe left two more times for "Disabled" and find the app and Enable it. It will auto update once it is restarted.
    It is not really kitkat causing the battery drain, it is the apps that Moto has deigned should be running all the time. No guesses to whose advantage that might be.
    02-03-2014 12:19 PM
  1. Nexus 5: Straight Talk MMS problem solution
    By Stillhackin in forum Google Nexus 5
    Last Post: 03-04-2014, 08:27 AM
  2. Google Now and battery life
    By aldo82 in forum Google Nexus 5
    Last Post: 02-04-2014, 11:55 AM
  3. Replies: 1
    Last Post: 02-03-2014, 04:16 AM
  4. How to upgrade Android to Kitkat?
    By bainwave in forum Android 4.0 Ice Cream Sandwich
    Last Post: 02-02-2014, 12:16 PM
